Spindle nut
- Regular Member
Spindle nut
Anybody know the thread size for stock front spindle nut that holds the wheel on for a vintage rc10 buggy?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Spindle nut
Depends. The steel axles used a 4-40 nut and the aluminum axles used a 5-40. If you can take a shock nut loose and thread it onto the front axle it's a 4-40. The only other 5-40 on the cars would be the diff nut if it's a 6 gear or slipper nut on a stealth. They are gold in color.
Ideally you should use a nylon nut. It will thread into either just fine and is both safe and secure
- 501 Views
Last post by lowrydesign
- 324 Views
Last post by juicedcoupe
- 1203 Views
Last post by sgirouard
- 1088 Views
Last post by FasterLouder
- 2521 Views
Last post by justinspeed79
- 1642 Views
Last post by templeofspeed
- 22 Replies
- 2498 Views
Last post by Halgar
- 29 Replies
- 2740 Views
Users browsing this forum: Bing [Bot],
Google Adsense [Bot],
Majestic-12 [Bot] and 3 guests
