king pins the same across 870C/yz10?
Have an 870C project and need kingpins. Are they the same size across the models? any suitable out there that are readily available? I was looking around for a screw/bushing setup as a replacement since it seems that tends to be more common.
Re: king pins the same across 870C/yz10?
I think all the models that used the metal steering knuckles would use the same king pins. Pretty sure Im using them on the 93 94 models too, but there might be a different part number for absolute correctness. Seems like the plastic c hubs on the long arm models is thicker and might require a slightly longer king pin. However,, Im using the 870c type on those long arm cars no problems.
A good common retro fit is kyosho ot-4. They look almost exact, and fit exactly perfect.
I bought a set of re re optima knuckles with the updated screw and sleeve type king pins. They dont fit anything. The sleeve is fatter than the 1 pc king pins.
awesome. thanks dude, that gives me good info.
from searching those parts down, they are anywhere from 10 to 40 bucks for them. I'll probably end up making my own bushings, hah.
I wonder if these would fit? Theres a crap ton of cheap king pins on ebay,, but no idea which ones would fit!
http://www.ebay.com/itm/Kyosho-FA021-King-Pin-Set-Rage-VE-EP-FAZER-/381813487575?hash=item58e5db77d7:g:CvsAAOSwZJBYABYa
- 560 Views
Last post by MIKE VALENTINE
- 2824 Views
Last post by aip47-2008
- 1279 Views
Last post by tamiyadan
- 809 Views
Last post by hondaman
- 3780 Views
Last post by GJW
- 1228 Views
Last post by Bormac
- 2689 Views
- 1157 Views
Last post by flustorm99
