Is this a Tamiya shock?
- Been thanked: 100 times
Got a 1984 custom built car which uses a mono-shock front end. I´m not sure what make this shock is but I was told this should be from a Frog where the shock body was machined for accepting collars.
Someone could confirm this or knows something different?
- Jirka
- Has thanked: 33 times
- Been thanked: 24 times
Re: Is this a Tamiya shock?
No, it is not a Frog shock. On Frog the spring is only around shock shaft and not around shock body. Also Frog shock body has "cooling ribs".
Jirka
Edit: well I am not sure after all. Can You open it?
Jirka
- Has thanked: 1134 times
- Been thanked: 3930 times
Thanks. Yes it´s not an original shock, the shock body was machined for removing the ribs so a longer spring could be used. But I was not sure if the original shock was borrowed from a Frog or different car.
Yes it´s a Yokomo 834b but it´s not a Yokomo shock. This shock is longer than the original shock. The previous owner knew it was a Tamyia shock which was machined but he was not sure if it was a Frog shock.
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Not an 834b shock, this is an 834b shock similar maybe but enough different.
This is all very interesting!
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
- 1473 Views
Last post by Delorean
- 725 Views
Last post by mamadoesntletme
- 37 Replies
- 13302 Views
Last post by jaro
- 4743 Views
Last post by Northy
- 1527 Views
Last post by Chickenpuff
- 2372 Views
Last post by hotrodlocal
- 23 Replies
- 1817 Views
Last post by Lowgear
- 1278 Views
Last post by Jay Dub
