Works 91 spur assembly - wasp racing??
Re: Works 91 spur assembly
yes, a wasp torque limiting clutch has been mentioned. cant find much info anywhere on it to check though
Re: Works 91 spur assembly - wasp racing??
Rw racing in the uk still sell the spur gears and in white or black plastic should you need more.
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
You sure James? With the large centre cutout....the spur is more like a ring....haven't seen any anywhere
I've got a WASP yoke slipper and it doesn't look like this it's like the ones that came on the Cats but this could be another design, have you got pics of it apart to see if it's the same inside?
I haven't but i'll strip it and post some tomorrow Justin
here it is...main body sits over the end of the layshaft incorporating a one way bearing, the the white plastic(?) disc doubles as the spur gear mount and slipper pad, then you've got the outer plate kept in place by a small plug inserted in the main shaft, 4 sprung washers and finally the outer round nut that acts as the slipper adjuster...that's it apart from what looks like they are going to be hard to source spurs!!....pics below
- 825 Views
Last post by vintagercfreak
- 29 Replies
- 5435 Views
Last post by DaveM
- 1195 Views
Last post by shodog
- 1999 Views
Last post by Mr. ED
- 860 Views
Last post by SMOKE-DOG
- 445 Views
- 1645 Views
Last post by dinglem
- 1893 Views
Last post by stulec52
