My Vintage RC10CE, Help!!
- Regular Member
Hello everyone, I'm new here and this is my first post. My 90's RC10CE brings me here today, It's been stored for over 20 years now, temporarily coming out of storage at one point for the kids to play with, it received a new speed control and motor at that point, only to be stored again until now. I've unpacked it again and no idea which way to go with it now. I'd either like to dress it up and upgrade it to be a little more modern but it seems that may be frowned upon in the RC10 world or just sell it for something a little more modern that my son and I can enjoy. I'd appreciate any advice, comments, or information on the car, value or where to acquire upgrades and parts. Thanks for looking everyone.
- Has thanked: 100 times
- Been thanked: 205 times
Re: My Vintage RC10CE, Help!!
That is a very sweet Survivor 6 gear Championship edition. I hate to say it but if I owned it I would definitely shelf it and get a Worlds Car re release which can be gotten around $150 and thrash on that.
Being an original 6 gear to put anything silly in it you should do a stealth trans swap.. and retail that is over half of what you can get that Worlds car for from places like Tower.
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- JK Racing
- Has thanked: 140 times
- Been thanked: 246 times
Great looking time capsule there...dont touch it (and I am an anti-shelf queen guy). Put it away to gaze at when you need to remember your youth.
Pick up a re-release Worlds or any other modern car for you and your son to beat around with.
- RC10th
- Has thanked: 55 times
- Been thanked: 1587 times
Wow, I like it as it is.
Hang onto it for nostalgia sake, don't sell it. It has a character you can't easily reproduce.
I would just clean it up a bit and maybe find some black aluminum shock caps, that's it.
Buy something more modern for the kids to play with.
Would a 6-gear transmission not handle a newer motor? What's the definition of "silly"?clm wrote:That is a very sweet Survivor 6 gear Championship edition. I hate to say it but if I owned it I would definitely shelf it and get a Worlds Car re release which can be gotten around $150 and thrash on that.
A stock 6 gear should do fine with a stock class brushless, one of those 17.5. Many buy a brushless system and attempt to see how long a car designed not to wheelie will wheelie or how fast they can make it go.vitamink wrote: Would a 6-gear transmission not handle a newer motor? What's the definition of "silly"?
The original 6 gear was designed in an era when motor/battery/esc were just no where even close to what you can get now for cheap from even the likes of Hobbyking, even the 3 gear stealth can be smoked with some of the modern power systems but with it's slipper clutch it has a fighting chance... Unless you lock it down to 'stunt drive' heh
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Silly is like dropping an LS1 in a C1.vitamink wrote:Would a 6-gear transmission not handle a newer motor? What's the definition of "silly"?clm wrote:That is a very sweet Survivor 6 gear Championship edition. I hate to say it but if I owned it I would definitely shelf it and get a Worlds Car re release which can be gotten around $150 and thrash on that.
If I could get my CE running with a 17.5, I'd be pleased as punch, just to see the old guy zipping around again.clm wrote:A stock 6 gear should do fine with a stock class brushless, one of those 17.5. Many buy a brushless system and attempt to see how long a car designed not to wheelie will wheelie or how fast they can make it go.vitamink wrote: Would a 6-gear transmission not handle a newer motor? What's the definition of "silly"?
(Need to do some mallet-work on the chassis to straighten out the bend it acquired from its bashing career, however.)
A transmission rebuild is also definitely in order. Any ideas on the most economical route to get a full set of bearings for this car?
If it has the 6 gear any bearing set for the recent Rc10 classic should work. You can get them from Avidrc.com or Bocabearings.com for about $16 for a basic set or a little bit cheaper with some ebay browsing.
- Regular Member
Thanks for the advice, since I posted the pictures I've taken the car apart and thoroughly cleaned all the parts. Thinking about storing the original pieces and rebuilding with some after market pieces that don't require modifications to the chassis. I'd like a black/gold color scheme and modern electronics. More pictures to come....
I would save that chassis too, many of the original gold chassis and noseplates are far worse shape then that and you can often get a re-re worlds chassis for fairly cheap to keep that in good condition. Good condition white parts are fairly easy to get, chassis/nose is hard to find due to them being the thing the car will always scrape on the ground
ReRe gold noses just don't cut it for a shelfer.. that original stamped AE logo really does it for me heh.
- Been thanked: 507 times
agreed on keeping that survivor intact. Maybe run it a little bit on carpet or carefully outside to get that nostalgia, but yeah, that worlds car at ~150 bucks is tough to beat.
- Regular Member
Cleanup is complete, the peroxide trick worked great on the white parts and everything is intact without broken any broken pieces. I did cut an end out of the battery cup at some point it appears to accommodate a larger battery and the tires are shot. I plan on shelfing most original pieces and going back with some updated pieces. I don't plan on changing or damaging the pan at all so it can go back to original at any point. I found paperwork stating I purchased the car July of 1991. Here is the progress....
- 604 Views
Last post by fluidpower
- 695 Views
Last post by RJK33
- 661 Views
Last post by Traffic22
- 862 Views
Last post by whisperingbomb
- 1072 Views
Last post by Synergy
- 1325 Views
Last post by markbt73
- 19 Replies
- 2415 Views
Last post by justinspeed79
- 3154 Views
Last post by CBR240
Users browsing this forum: Tbot [Bot] and 12 guests
