Leftover parts build?
Jimbo302
Has thanked: 14 times
Post by Jimbo302 »
I know I have seen several others go this route. Gather up all the spares and second string parts you have and create a runner. My question is, just how effective is that? I can see myself ordering a ton of new parts to build a beater that never was and spending too much in the end.
I started picking through my extras and found these thoughts running through my head.
clm
Has thanked: 100 times
Been thanked: 205 times
Re: Leftover parts build?
Post by clm »
Jimbo302 wrote:I know I have seen several others go this route. Gather up all the spares and second string parts you have and create a runner. My question is, just how effective is that? I can see myself ordering a ton of new parts to build a beater that never was and spending too much in the end.
There is where you are wrong.. you don't buy new parts FOR the beater... but you buy new parts for the good ones that just happen to have the lesser quality parts the beater needs :D
The only real exception is stuff like a shock rebuild or a diff rebuild. But mangy missmatched tie rods and the like are fine. As are tires to attach to reclaimed rims... or just use bald tires as slicks! lol
If your Leftover needs parts see if any of your good cars need those parts replaced and go from there.
The big problem here is when your mind goes into 'lets make this car nice' mode and you start buying nice stuff for it lol
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Jimbo302
Post by Jimbo302 »
I see your point. I do have the tendency to want to take things too far. maybe not into "perfect" territory, but when performance is concerned, I tend have a break it and upgrade it philosophy.
Whoops. I thought I posted this in the buggy section.
clm
Post by clm »
Performance.... Toss leftover brushed motor and esc in in and beat on it until it breaks then toss more used parts on it and run... Maybe some beat up second hand RPM parts... :)
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
You end up spending lots more then buying something complete. I have come to realize if it needs a tranny, shocks or any major parts it's not going to end up cheap.
Jimbo302
Post by Jimbo302 »
RC10th wrote:You end up spending lots more then buying something complete. I have come to realize if it needs a tranny, shocks or any major parts it's not going to end up cheap.
This is what I was thinking.
rctenracer
Been thanked: 81 times
Post by rctenracer »
I have built up beaters using scrap parts . Bent tubs , stripped out threads on the nylon parts , and all that other scrap the should go in the trash. When you have to buy a part for a beater they become resto projects or money pits.
clm
Post by clm »
rctenracer wrote:I have built up beaters using scrap parts . Bent tubs , stripped out threads on the nylon parts , and all that other scrap the should go in the trash. When you have to buy a part for a beater they become resto projects or money pits. Beaters are fun to run .
I don't know... I would probably say 'when you have to buy a part to replace a perfectly serviceable part just to make it look better would be more of a money pit'... If you bust your last a arm and have to buy new ones just to run it is not really a resto :)
Return to “RC10 Truck Forum”
