Okay... so I may have been right earlier , that this was originally a Championship edition , 6001 kit. It has the offset non countersunk battery tray holes.
the original rear bulkhead & shock tower that was on it when I first got it was what lead me to think that from the start.
This might turn in to a CE build. I can swap out the rear bulkhead, shock towers for the newer ones.i already have the correct rims and front tires.
I will need to find correct shocks and the diamond shape nose plate too.
1 step at a time though. At least it's a roller now!
I have wanted one of these since my best friend from childhood had one in the late 80's. I picked this up on eBay last night, hope I didnt get hurt too bad at $300. It was advertised as an A stamp Andy's edition . What can you all tell me about this...
The tires for the 1.9/1.7 JConcepts can be hard to find at times.
They are overseas but JC Racing has wheel options for both axle sizes.
Alternatively, you can use the above 2.2 JConcepts fronts and Traxxas 7171 rears with Factory Works rear...
Here is my attempt to restore a gold pan rebuild. I took these photos with the Iphone. My plans are to run the B4 Wheel setup. I have a bunch of parts on the way: B44 CVA's, and Inline front axle setup. I want the gold shock bodies and will pick up...
beginning to look good ;)
if you have an LP servo, might has well get the link centered properly ;)
I changed out the rear suspension mounts because one was cracked, when I took the old ones out I noticed somebody had cut them down, why would they do that?
Also does anybody know what these black rims are? I striped one of them out and I bought...
Does that car have rear hex conversion?
If so, use Traxxas 7171 wheels.
That's why I was curious about the axle picture. For rears with the 3/16 axle it seems easy enough to switch from hex to...
Hi Everyone,I recently aquired 2 RC10 gold pan cars with boxes 1 is a #6016 and the other a #6020 ,now from what I've come to understand the 6016 is a ball bearing equiped version of the 6020 don't know how true this but im am definitly addicted to...
i was given a RC10 gold pan..............i need some parts (motors,shocks,radio gear/radio) and one know where i can get these parts for cheap ................... if you want to see my toy there's where you can find my pics of it
Enjoy
Smurf
hahahaha i didn't realize i had two.............i usually have so much going on at once it's easy to do
Hello all, this is my 1st post on here. so here is goes I'm not new to rc's (I have 2 hpi bajas had lots of nitros and electric), my 1st rc was a rc10 gold pan and rc10t years ago (80's and 90s). I just picked up a rc10 gold pan and missing a couple...
going look at them now. guess i should have done that 1st :?
Hey everyone, this is my first post here and i was hoping for a little help with electronics for my gold pan buggy. I've got all of the shocks and arms and everything in full working order and fabricated a servo to steer linkage. I currently have a...
all good. thanks buddy :D ... i did decide to stick with an original brushed reedy modified competition green label sinc ethat is what my car came with originally. i found one in great working order used on ebay for $22 :D it runs plenty fast for...
