Ball stud sizes/quantities for RC10t?
Talked to Lunsford about ordering some punisher turnbuckles and they were able to put a kit together for me. I'd like to order some all new ball studs as well. Just not sure on sizes and quantities for those. Anyone know for sure?
Re: Ball stud sizes/quantities for RC10t?
Damn didn't even think of that! Thanks!bully wrote:Download the manual from ae mate.. Best bet
These are what I was looking at:
http://www.lunsfordracing.com/mm5/merchant.mvc?Session_ID=a2e9f5b0ab7d6e1872868edc53f9c3ea&Screen=CTGY&Store_Code=LUNS&Category_Code=BALL
- jeepy2013
- Been thanked: 4 times
What did Lunsford put together for you as a kit? I'm considering doing Lunsford on my 10T runner to get rid of the old rusty (and bent) stock ones.
- TRX-1-3
- Has thanked: 2067 times
- Been thanked: 992 times
Lunsford usually sends ball cups out with their turnbuckles. It kind of encourages you to buy their titanium ball studs that fit those cups perfectly. would be thread type would be important though duh.
Lunsford duplicated the specs on the site associated lists on their site for the 10t. I think it was like $33 mailed for the rods. I bought RPM ball cups separately so hopefully those work!
From the email:
Yes, we can help you out with your RC10T. Back in the day we did have a turnbuckle kit for it. Here's what we can do:
1 - 3mm x 1"
1 - 3mm x 1 5/8"
6 - 3mm x 2 5/8"
From the email:
1 - 3mm x 1"
1 - 3mm x 1 5/8"
6 - 3mm x 2 5/8"
https://www.teamassociated.com/pdf/cars_and_trucks/RC10T/Team/10t_old.pdf
OK after looking at the manual above this is what I came up with:
6270: 7
-2 front shock tower
-5 bell crank assembly
6273: 8
-4 front steering blocks
-2 rear shock towers
-2 rear hubs
Am I missing anything?
6270: 7
6273: 8
-2 rear hubs
- Been thanked: 5 times
I've been using the 6277 lately for long ball studs. They're so much easier to install in the rear bulkhead. Depending on your bump steer spacers you may not need the long size at the axle block.
- Has thanked: 727 times
- Been thanked: 26 times
Hi,
One # 6270 for the servo arm.
I use 2 x #6270 in the rear shock tower, if you look in the manual, page 24, figure 79, the longer # 6273
ball stud threads stick out, whereas if you use # 6270 ball studs they are flush.
Everything else looks spot on.
- 1274 Views
Last post by romulus22
- 140 Views
Last post by TravelinTravis
- 758 Views
Last post by Daddeo
- 568 Views
Last post by losiXXXman
- 692 Views
Last post by Toyotachris1982
- 932 Views
Last post by USA-1
- 1748 Views
Last post by mark in wi
- 7829 Views
Last post by Bimdapogs
