OK, its the late 1980's....your rich uncle shows up and takes you to your LHS...anything you want.... You choose a 6020 full kit...he says to you, OK how we gonna hop this up?
What hop up parts do you add and why? You'll be running on a decent semi-competitive off road course...
Be specific! Cost no object but parts have to be "off the shelf" commercially available and nothing after 1990...
How would you set yours up?
- Has thanked: 36 times
- Been thanked: 1318 times
Re: How would you set yours up?
an mip trans. no explanation needed.
probably some parma heavy duty heim ends with technacraft turnbuckles for durability. also, an a&l or houge steering bellcrank.
- Been thanked: 12 times
are you allowed to use modern radio gear(tx/rx) or does everything have to be pre1990?
can anyone enlighten me as to which iteration of rc10 a 6020 kit is?
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
6020 was a gold tub kit with battery...probably the white GE Saft 1000mah. not sure if it was a bearing kit though.
So if you were going to hop up a 6020 in 1989, probably best to grab a 6030 Graphite kit as well (you said your uncle was rich...).
And since uncle bucks is paying, why not have Jim Halsey build it?
Kraft/KO radio and Rx, Futaba S130 steering servo, Novak T1X. Better batteries...seven cells. Reedy timer/temperature charger. Wicked Reedy 17 turn motor (gold star?)
And the stuff scr8p mentioned to harness all that horsepower.
So, got it built yet?
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
JG bumper, Losi 4 row spiked tires, Proline waffle fronts, Proline wheels, Gonzo batteries, Checkpoint motor, RCRC/Ascot sprint car kit
Oh wait...that was my shopping list back then. I miss dirt oval.
- 683 Views
Last post by Tamiyaterror
- 726 Views
- 531 Views
Last post by George Pravata
- 811 Views
Last post by Trackingz
- 33 Replies
- 3416 Views
Last post by tizeye
- 1252 Views
Last post by treehugger
- 446 Views
Last post by Brandon G
- 1271 Views
Last post by MattyCJ7
Users browsing this forum: Google [Bot] and 3 guests
