Just pulled out my RC10 T original shelfie
thodgez28
Post by thodgez28 »
Still debating if I should run her.......rebuilding diff as we speak.....thinking about a castle engine speed combo.......any suggestions? Where can I find tires for this thing anyone have a good source?
klavy69
Moderator
Has thanked: 640 times
Been thanked: 294 times
Re: Just pulled out my RC10 original shelfie
Post by klavy69 »
what kind of tires are you talking about?
any 2.2 will work on it but you'll need to get different rims for the newer tires. The newer tires are too soft and will pull thru those 3 pc wheels.
If you are talking about replacing with older more time line specific tires ebay is your best bet but not thinking you were after those if you were going Castle in it.
thodgez28
Post by thodgez28 »
Probably dirt hawgs on new rims.... How hard is it to find new rims?
klavy69
Moderator
Post by klavy69 »
Not hard at all. You have 1/4" axles on that truck but most are 3/16" axles anymore. If you get 3/16" axle wheels you can 'drill' them out with 1/4" bit. I do this by hand to fit them to the axle or set up a drill press and a stop on it so they only drill into the axle hole an 1/8 of an inch so the wheel fits over the axle. All rc10t, t2, gt, gt2 wheels have the same offset but again most of these are going to be 3/16 axles. Ebay has a butt load of wheels all over the place for these along with online hobby shops.
Here are a few dish rears just off the first page of ebay searching for associated wheels
1/4" rears white
rear wheels black
gt2 rears in yellow
and these are just associated. Depends on how hard you want to look for wheels and the style. RPM makes some nice wheels for the rc10t trucks also like the
revolver
bully
if you want a little different look than just a dish wheel.
thodgez28
Post by thodgez28 »
Hey thanks that helps a lot :D
thodgez28
Post by thodgez28 »
Ok so got some TRC foams for rc10t but the axels seem barely long enough to get a bite with the nut.....can I upgrade to the t4 mip cvd's and have a longer stouter axle shaft? Should I need new hubs as well?
RS Chris
Been thanked: 19 times
Re: Just pulled out my RC10 T original shelfie
Post by RS Chris »
If you already have CVDs then just put on T4 axles. They are about a 1/4" longer. If not then you will have to find a whole kit. I don't know if a T4 CVD kit will work on a T1. Asked that question a while back on another forum on got crickets for a response. I do know that GT, T2, and T3 CVDs will fit fine. On my T1 I'm using an original MIP kit for it with the T4 axles. You will need to shim the longer axle some more as the pin is further out from the hub. But there is nothing difficult about it. And the hubs you have will work fine unless they are just worn out.
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
bully
Been thanked: 6 times
Post by bully »
T4 bones are longer and won't work with the usual 10T rear hubs.. Try a low profile nut on the axle first
Lavigna
Has thanked: 1100 times
Been thanked: 1419 times
Post by Lavigna »
That thing looks too pretty to drive. Can you post some more photos, with the body off?
thodgez28
Post by thodgez28 »
It's never been driven.....yes I'll post more as soon as she's back together :D .....rebuilding the diff. Just to be safe since the grease had all settled in the bottom and had become sludgy.....
thodgez28
Post by thodgez28 »
thodgez28
Post by thodgez28 »
It's a B stamped chassis
jeepy2013
Post by jeepy2013 »
thodgez28
Post by thodgez28 »
Yes I have original 3 piece wheels.....wanted the foams for street use.
RS Chris
Post by RS Chris »
A 10T with pro-line rims and foam tires is a hard look to beat.
Return to “RC10 Truck Forum”
