.89" front shock swap
General info, Q&A.
RS Chris
Been thanked: 19 times
Post by RS Chris »
Who has done this swap? I can find complete kits on Associated's website, but not the individual shafts. Closest thing I found is a .80" shaft, pn. 9723 for B4, B44.
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
Been thanked: 3917 times
Re: .89" front shock swap
On a B3 for example the shock body is a .89 but the shafts are .71. Part number 6460
RS Chris
Post by RS Chris »
Interesting info there GoMachV.
Looks like I'll have to piece together the setup I want then. Going with .89" V2 bodies with .80" shafts.
harvey
Post by harvey »
I think the longer bodies are to achieve less displacement from the shaft. Even the B4 uses .71's. If you want travel you could consider 1.02's and get less displacement (you need more air the farther in the shaft is driven, which means a bigger bubble / more foaming).
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
I run .89/.71 shafts on most of my 2wd buggies. They are great. The .80 shaft was for the b44 series, which needed a bit more stroke than a 2wd. Keep in mind, the stardard front buggy springs are really short...the .89/.80 combo may need to have tons of pre-load
harvey
Post by harvey »
Hey Joey, what was the length of body the b44 used with the .80's?
bully
Been thanked: 6 times
Post by bully »
The same 0.89
JK Racing
Post by JK Racing »
Bully is correct, .89
alien3t
Post by alien3t »
But the b44 with those shocks also ran a different lower spring retainer also.
