Getting an old abused car running again.
- Has thanked: 14 times
- Been thanked: 5 times
Re: Getting an old abused car running again.
I'm noticing battery fitment might be an issue. Is there a different setup to use when changing the battery position?
- yellowdatsun
You can get a "shorty" pack, and move the battery holder to fit, that's what most of us do. Either front-to-back, or sideways.
Yes, you can use your old servo, no issues there.
You'll learn a lot in a very short amount of time, in regards to the new tech available. That's how it was when I got back into RC.
It looks like the lipo pack I ordered will fit the front to rear mounting setup.
5 x 2.1 x 0.9 inches.
Thanks for your input.
- yellowdatsun
You can also make a spacer from foam, which is what's in my car. The battery is in the forward position, and the foam in the back.
or ask GoMachV, i had him make me a battery strap for shorty in my rc10's. but its designed like the Schelle in my T5M. its a little longer than the shorty pack, but there is a slot for a screw and a ball cup to hold the backside of the battery. these leaves open air behind the lipo to run a esc with a fan and no battery strap to interfear.
I plan to run thumb screws, and the slot will get a screw and ball cup.
The paint didn't turn out so well. I'm fine with it, a basher needs a basher body, right?
I have a set of original decals coming for it as well.
- yellowdatsun
Decals and trim tape do a LOT to help a not-so-good paint job. Use the trim tape around the window edges, so it looks like rubber molding, or silver like stainless trim. I've painted a lot of bodies, and trim tape does wonders.
I put the ESC in today. The 15t motor was pretty good on the 7cell NIMH pack. But the stock motor on 3s lipo was a blast! (Until it smoked the motor!).
I'm going to order a smaller pinion gear to see how it does. I've got 48p 56/16 stock, right? How does a 13t pinion sound?
- yellowdatsun
- 932 Views
Last post by mark
- 839 Views
Last post by Bharper
- 2433 Views
Last post by trek
- 1791 Views
Last post by Lizardking
- 579 Views
Last post by corkyjohnson75
- 1697 Views
Last post by slow_jun
- 1395 Views
Last post by Bormac
- 553 Views
Last post by ChisaiKuso
Users browsing this forum: Mojeek [Bot] and 0 guests
