early 90's battery connectors, help!
Tamiyaterror
Post by Tamiyaterror »
hi, im searching for some advice on an early 90's shelf queen project im currently building, im looking to replace the tamiya plug on the speed controller with something a bit more race spec! can anyone suggest something that was around at that time? i remember on my old cars back in the day i had long black and red connectors which were seperate pieces, cant remember what they were called tho, or find any pictures!
any advice would be greatly appreciated.
tamiyadan
Been thanked: 6 times
Re: early 90's battery connectors, help!
Post by tamiyadan »
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Sermos plugs were also known as Anderson Power Pole connectors.
Direct solder or bullets were others.
Tamiyaterror
perfect! thanks guys, exactly what im after
Tamiyaterror
do you think 30amp would be man enough for the job?
30 amp are the standard ones for that size, and would be perfectly fine. Those anderson connectors are actually a whole family of connectors that vary in size as the current goes up. I've seen them as big as your thumb for each conductor.
