RC10 driveshafts
- squirrelnutz
RC10 driveshafts
Hey guys, I'm doing a custom build that involves using the rear suspension and CVD's from a B3. I won't be using the B3 tranny but I want to use a Lethal Weapon tranny. I got the B3 used and the driveshafts don't seem to be the proper length. They seem a bit short and look like they will pop out of the diff cups. I'm guessing if I use the Lethal Weapon transmission I'll run into the same problem.
I'm wondering if I could use a set of B4 CVD's with my B3 or would they be too long? Would anyone be able to take a measurement of the B4 CVD's for me?
Thanks!
Thanks!
Re: RC10 driveshafts
it's hard to say what you have without seeing it. A set of B3 CVD's should fit a stock B3 just fine. B4 CVD's are about .400" longer so unless you have B4 hubs, they will bind badly.
CVD's are a pain because one end is fixed, leaving all the 'slide' function on the drive side. If the camber, axle shims and shock inner bump stops are not correct, the bones will pop out.
- squirrelnutz
Just from looking at the picture of a B4 CVD, I knew it was a bit longer. Here's a picture of what's going on with my B3. It looks like it may be an aftermarket MIP shiny CVD or something.
- Been thanked: 7 times
Take a look at my post B2.3.4 Racer. I replaced the original universals with a set of the CVAs from the Worlds re-release. I had to shim the hell out of the axle, but the bone end fits just fine in the hub. A few other members mentioned using the shafts from the B44 (rear center I believe), which is slightly longer. If you have a local hobby shop with decent stock, I would just go measure a few shafts and see what works best. That is what I am going to do to eliminate some of the shims.
- squirrelnutz
I know the A&L tranny is not going to fit the stock chassis. I'm going to be cutting a new chassis from a fiberglass sheet to fit the new transmission.
- 913 Views
Last post by brian s
- 938 Views
Last post by moozo
- 2993 Views
- 744 Views
Last post by buttmonkey1969
- 765 Views
Last post by DerbyDan
- 860 Views
Last post by CNA75
- 1735 Views
Last post by moozo
- 48 Replies
- 20534 Views
Last post by Turbobuick
Users browsing this forum: BIGDADDYBUILDER and 4 guests
