Bearing kit
ryukotse_yuki
Bearing kit
Post by ryukotse_yuki »
So does anyone know where to get a full bearing set for the 10T?? I bought a wheel bearing set recently that was too wide for the rears and would like to redo all the bushings to bearnigs. And if not a kit than bearing size/number of each size list. As well as how the heck do i get rid of the insane wheel wobble on both the front and rear! THANKS FOR THE HELP!!!!!
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Bearing kit
Post by RC10th »
Can you post pics of what hubs and axles you have?
Re: Bearing kit
A lot of the wheel wobble is the bushings. Changing to bearings will help that. But bushings also wear out the axles, so you may want to replace those as well. Especially is the truck saw a lot of use.
ryukotse_yuki
Re: Bearing kit
I will post pics sortly. bearings in the front did nothing to reduce wobble, and it was run 6 times and shelved back in the day!
ryukotse_yuki
Re: Bearing kit
here are the pics
Re: Bearing kit
You definitely have the wrong bearings. They should not be flanged, front or rear (with those hubs).
I don't see a proper kit anywhere, but here's what you need.
8 ) 3/16 x 3/8 plain - front wheels, trans top shaft and idler
4 ) 1/4 x 3/8 plain - rear hubs
2 ) 5/32 x 5/16 plain - inside diff
2 ) 3/8 x 5/8 plain - trans outdrives
http://www.avidrc.com sells them for $1.00 a piece.
RC10th
Re: Bearing kit
Post by RC10th »
I think you meant (8) 3/16 x 3/8 for front bearings and trans.
You'll also need (2) 3/8 x 5/8 for the trans.
Re: Bearing kit
RC10th wrote:I think you meant (8) 3/16 x 3/8 for front bearings and trans.
Oops, yes. Thanks for catching that. I was kinda doing something else at the same time and wasn't giving it my full attention.
I edited my above post.
ryukotse_yuki
Re: Bearing kit
thanks a lot BIG help!! much love. I cant wait to have this guy running well. the only new things on it are the motor which wouldnt turn when i got it and the rx/tx. will keep t that way for a good while hopefully!
Ronbo
Has thanked: 23 times
Been thanked: 63 times
Re: Bearing kit
Post by Ronbo »
Boca bearings also has a $16-17 kit that looks like it has all the bearings for Rc10, 10T and Yokomo Yz10. Just use the search engine on site.
RC104ever
Re: Bearing kit
Post by RC104ever »
Avid RC has bearings that you can buy individually. They are excellent quality too.
- Chris
Lots of cars...so many cars
Return to “RC10 Truck Forum”
