Recently acquired an Optima - seeking some opinions
- Regular Member
Re: Recently acquired an Optima - seeking some opinions
Have an 80 tooth spur gear, and 75mm tire diameter. Looks like a 22 or 23 tooth pinion would put me in the neighborhood of 1 for my rollout ratio? Feel free to double check the math for me.
- Been thanked: 276 times
23T looks almost as close to 1.00 as you can get, but 22T and 24T are both within 10%, so I'd start with a 23T, monitor motor & ESC temperatures...if temps are fine, use a 22T if you want quicker acceleration, and a 24T if you want a higher top speed...or stick with the 23T. Let me know how it goes, and which pinion you chose. A few members have used my calculator and the feedback has been positive.doublfelix wrote:Have an 80 tooth spur gear, and 75mm tire diameter. Looks like a 22 or 23 tooth pinion would put me in the neighborhood of 1 for my rollout ratio? Feel free to double check the math for me.
If you change your tires and the diameter changes, simply re-calculate for a new pinion that gets as close to your desired ratio as possible.
- EvolutionRevolution
- Has thanked: 20 times
- Been thanked: 36 times
Kyosho one-way diffs use the gear diff housing.Coelacanth wrote:A one-way front diff...nice option. Those are pretty pricey on eBay these days!
- Regular Member
I found a bumper and the battery holder on ebay, so those should be arriving sometime in the next week. I still need to source a lower belt cover and spur gear cover. I see that Team Bluegroove offers a repro set that includes the upper/lower belt covers and the gear cover (this set now apparently is in Version 2). Does anyone have experience with these sets? The other option I've found is an original gear cover, and then a JG1516 belt cover set. Option 2 is considerably more expensive, but I can get pinion gears from that seller as well....so once I decide which route to go here, I should only need to add electronics and a body to get up and running finally.
- Regular Member
Can someone with knowledge confirm for me: the pinion / spur for the Turbo Mid SE is 0.6 module / 32 pitch, correct? Hoping to make one more order of parts and add some electronics before I'm able to take it for a test drive.
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
MID is running 0.6M std.
0.6M doesn´t equal 32dp - not even 48dp!
0.8M and 32dp are almost the same.
Gone fishing
- Regular Member
That's right DennisM, too much late night browsing / posting by me. Thanks!
- 1296 Views
Last post by Mad Racer
- 1294 Views
Last post by teman
- 626 Views
Last post by klavy69
- 606 Views
Last post by teman
- 1197 Views
- 1700 Views
Last post by Seabass
- 1363 Views
Last post by Harrylarry
- 816 Views
Last post by briang
Users browsing this forum: Facebook [Bot], fotomatt1 and 0 guests
