RC10 Yard Bashers! Lets see yours!
- R Cane
- Has thanked: 155 times
- Been thanked: 63 times
Re: RC10 Yard Bashers! Lets see yours!
My B2 runner...all true B2 parts, with about half of the OEM carbon upgrades. Ok, the titanium 'buckles and hinge pins, and the RPM cups and gear cover are not original...
Just got done with a tear down and cleaning / replacing worn parts. Just need to get the electronics back in, and it's dirt time.
It's got an LRP IPC 7.1 ESC, and this time for the motor, I think I'm going to try out a Trinity D4 11/2 that I've got. Of course, updated to 2.4GHz receiver, so I don't have to mess with crystals...
- yellowdatsun
Here's mine, another RC10T Buggy!!
Talk about long travel suspension!!
It may be newly minted, but it's 90% used parts, and will be my new outside basher car. Most of my others have become too nice to run outdoors, IE: Beautifull B4, new B5M, and heavily modified Slash 4x4 for racing, along with a vintage 80's Ultima, and various vintage RC10's.
Since I know the question is going to come up, the plastic triangles on the sides act as nerf-bars, to protect the rear suspension. They are indeed vintage, probably late 80's when everyone was using this kind of plastic for bumpers. Especially when you run truck long arms, you need something like these. On my other RC10T that I do run at the local clay track, I can't tell you how many times I've broken rear a-arm hinge pin holders. I'd put them on that car, but I don't want to add more weight
- Showcase1186
- Has thanked: 14 times
- Been thanked: 57 times
- vintage AE
- Has thanked: 29 times
- Been thanked: 35 times
I'm lovin these runners. Here's my one runner, that's never been raced that is.
With her Toyota family
- Martco78
So.... you know what its like as you browse eBay. You see something and a plan hatches.
This time it was a lonesome lightened A-stamp pan, cleverly cut to provide a shorter wheelbase option.
Next it was a Houge steering set complete with turnbuckles, arm mounts, hubs, axles wheel-nuts and bearings. A quick addition of a set of new RPM front arms, some vintage pins and the front end is up and running. (The B5 shocks and multi-hole tower came from the spares bin - You know how it is)
This one will be the speed demon with a lipo/brushless system I have currently installed but not run in my pretty re-re Classic shelfie.
I have wheels and a 6-gear transmission so just waiting for for some back end parts to appear or be bought.
So that's three in the garage now
- Has thanked: 6 times
- Been thanked: 100 times
man thats sweet looks like a proper vintage racer from back in the day. nice!R Cane wrote:My B2 runner...all true B2 parts, with about half of the OEM carbon upgrades. Ok, the titanium 'buckles and hinge pins, and the RPM cups and gear cover are not original...
- Martco78
Did some more work on the lightened special: Added the steering servo at an angle to give more space for the lipo battery in its cut-down battery box in the shorter chassis and positioned an Absima ESC and receiver.
In sorting out the steering had to drill new positions for the upper front turnbuckle ball on the shock tower so give clearance for the Houge steering connections on full lock.
Also gave a vintage 6-gear transmission a strip and check over before attaching.
-PeterWestcoast10z wrote:Meet "the Rat", my active duty cadillac RC10
Looking for a lipo that will fit sideways and in the stock battery cups, like yours, mate. Can you tell me make/model/online shop to get it?
- Martco78
Finally got the rear end sorted only to find my lipo won't quite fit. A quick fiddle around and a couple of new holes for the battery box has me now working a diagonal theme.
First run out found it very quick off the throttle, enough to wheelie on the shorter wheelbase. all went well until a glancing blow with a kerb at speed broke one of the steering arms. As I suspected it was a dyed black vintage part, but my box of spares provided a good condition replacement for the next run.
Pretty happy so far.
- JK Racing
- Has thanked: 103 times
- Been thanked: 199 times
Those are some gnarly looking rear tires, what are they?
- Martco78
JC Racing do a good range here in the UK.... and cheap.
http://www.jcracingproducts.co.uk/tyres?product_id=212
They are set on their excellent vintage RC10 conversion wheels. Direct fit and access to modern sized tyres.
http://www.jcracingproducts.co.uk/clearance/rc10
- yellowdatsun
Had plenty of RC10's over the years, and have never seen a diagonal battery layout until now. Seems to work ok though. With shorty batteries it's not necessarily a need, but with full size packs I can see it as a solution to servo placement.
- Martco78
The only minor issue I had with the servo position was the servo arm ball mount fouling the end of the adjacent nose tube. Because of the modified nose plate position (about 14mm shorter on the wheelbase) the nose tubes extend further back into the pan, but as there is plenty of spare length doing nothing I just cut one short.yellowdatsun wrote:Had plenty of RC10's over the years, and have never seen a diagonal battery layout until now. Seems to work ok though. With shorty batteries it's not necessarily a need, but with full size packs I can see it as a solution to servo placement.
You can see in the pictures the shorter tube and the difference between the original side fixing hole and the new.
I had a good rough session on tarmac with it with a fair few collisions, rolls and flips, largely down to the rather too-good traction from the modern tyres. (I really need something that slides a bit better for a bit of drift action.) Nothing further broke, but once back on the bench I could see the lightened pan had deformed a little inboard from the suspension mount points and it was obvious that the lightening process had weakened the pan integrity somewhat.
- 65 Replies
- 12402 Views
Last post by knucklebuster
- 597 Views
Last post by justinspeed79
- 2290 Views
Last post by RC10th
- 19 Replies
- 2006 Views
Last post by Mindwarp
- 251 Views
Last post by Lavigna
- 2221 Views
Last post by Johnboy72
- 31 Replies
- 3707 Views
Last post by sandkil
- 81 Views
Last post by discgolfer72
