BEATEN UP YOKOMO 834B DOGGY
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: BEATEN UP YOKOMO 834B DOGGY
That turned out fantastic. I'm curious what size bearings you used in the rear trailing arm mounts
- Regular Member
It just use the flanged 5x10 bearingshodog wrote:That turned out fantastic. I'm curious what size bearings you used in the rear trailing arm mounts
Thanks, i think it came out awesome much better than i first thought.shodog wrote:That turned out fantastic. I'm curious what size bearings you used in the rear trailing arm mounts
I didnt really no how to assemble the rear trailing arms because the delta parts dont come with instructions but i used 5, 5x10x3 bearings
on each side one on each side and 3 to act as a spacer but im sure i have done it wrong but it works for now as its only a shelfer.
What a great job! I had a half a dozen of these in the late 1990s and sold them all off. I always liked these cars. If there is on part I wish someone would remake, it's the gearbox for the 834b. It's the hardest part to find and/or duplicate.
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 54 times
Just put up on eBay some ERROR Bolink Funco 834b Half Bodies. They don't have any scoops on them. These had been done at a plant that was not getting things done correctly. I have moved to a different plant now since then. Don't plan on running this mold again any time soon. So if you need one and don't mind the problems you can get one at a good price.a01butal wrote:Yes, Mrlexan did repro the Funco version before but I think this mold is now with the Sabula Tech and I've not heard of them producing any bodies as yet.
Link to the bodies on eBay. http://goo.gl/1KMNJO
Edit - first set sold out in less than 24 hours. Here is 2 more sets but they are worse, and cheaper.
Set 2 http://goo.gl/zW8oB1
Set 3 http://goo.gl/X5dzC4
- Has thanked: 2237 times
- Been thanked: 1970 times
That looks stunning ,I can't wait to get mine finished.
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
This is a photo of the original body NIP and the header card says it is designated ZB-GL, I think I got this picture off Yahoo Japan a number of years ago and I think it sold for pretty big money back then which probably was at least 5 years ago. So very rare!
Oops! I guess if I had looked at page 2 instead of going from page 1 to 4 I might have seen this picture already posted so I have now removed it. Sorry.
This is all very interesting!
- 77 Replies
- 7333 Views
Last post by Dadio
- 1652 Views
Last post by Lastenfield
- 1339 Views
Last post by Jerzi
- 1532 Views
Last post by rcpitwork
- 1144 Views
Last post by shodog
- 3258 Views
Last post by coxbros1
- 3261 Views
Last post by naushad
- 2207 Views
Last post by highwayracer
