OT-76 hard pinion confusion
In my search for a hardened pinion for my optima I've come across a few variations of the ot-76. From what I've read, it should be a dull grey but the ones I've come across are not. They are clearly marked OT-76 hard final pinion on the packaging hence my confusion. Are these "shinier" pinions inferior?
- Been thanked: 325 times
Re: OT-76 hard pinion confusion
Thorp also made an upgrade gear, I believe made from steel. I managed to score a few of these over the years. Pick one up from this seller (not me) and save yourself a few bucks.
http://www.ebay.com/itm/Vintage-THORP-Dirt-Burners-4738-Ultima-Maxxum-Optima-Javelin-OT76-Final-Pinion-/191756032060?hash=item2ca58cd83c:g:qeYAAOxy7MtRr9fT
- Has thanked: 1129 times
- Been thanked: 3919 times
You can also use a 5mm bore Robinson pinion gear. They for great. Can't recall the tooth count but a whole lot cheaper!
Thanks guys. With the hardened pinion, how hot of a motor can these diffs handle? I know that the chain drive won't hold up to today's mod motors but I'm just wondering about the diff itself.
Somebody posted a topic on here about that...I believe it was a great alternative, dirt-cheap...but also needed spacers as the pinion gears were shorter. I believe the final pinion gear is 19T...can someone confirm the pitch?
It's 32 pitch and 19t sounds correct. I don't recall spacing it on mine but I must have
- losiXXXman
- Been thanked: 5 times
Thank you guys. I ended up buying a hardened final pinion off eBay . I know I over payed but who knows what or if any will show up in the future.
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
The easy way to identify a OT-76 pinion is that the hard pinion has a groove machined into it, as can be seen here.Grunger73 wrote:In my search for a hardened pinion for my optima I've come across a few variations of the ot-76. From what I've read, it should be a dull grey but the ones I've come across are not. They are clearly marked OT-76 hard final pinion on the packaging hence my confusion. Are these "shinier" pinions inferior?
Yes, I made sure it had that ring around it . The one I bought is shiny like the one in your pic. Some sort of hardened aluminum I would assume??terry.sc wrote:The easy way to identify a OT-76 pinion is that the hard pinion has a groove machined into it, as can be seen here.Grunger73 wrote:In my search for a hardened pinion for my optima I've come across a few variations of the ot-76. From what I've read, it should be a dull grey but the ones I've come across are not. They are clearly marked OT-76 hard final pinion on the packaging hence my confusion. Are these "shinier" pinions inferior?
not likely. probably steel, if hardened any significant amount. can be coated about 10 different ways, could be chrome plated, polished, cadmium, chromate, etc.
yes, i recall that the final pinion can be replaced with a robinson motor pinion a lot cheaper.
- 914 Views
- 24 Replies
- 2397 Views
Last post by treehugger
- 4224 Views
Last post by 85Edinger
- 2363 Views
- 3005 Views
Last post by LoboNYC
- 2896 Views
Last post by DerbyDan
- 3290 Views
Last post by blubblood
- 3206 Views
Last post by tiger1
Users browsing this forum: Mojeek [Bot] and 1 guest
