RC10 Shock Bind
RC10 Shock Bind
So, I've been getting great help for my gold pan i am restoring to do a rest mod. And so here is another question, about a shock. When i emptied the shocks of their oil and contents. (this shock has seals still), The piston is sticking to the interal shock body. it ws never like this before. the other shocks are fne but i havent done anything to the shock to cause this. IF i were to just put the oil in, would it be fine and i can go on rebuilding more. or do i need a new shock body? and when i put the new silicon oil in the shocks, would the older seals swell? or do i need to replace all four shocks? These are bottom loading shocks.
Newly Rebuild Edinger RC10
B4.2, B5M Factory Lite, B44.3, And RC10 Graphite w/ Stealth trans.
LRP Esc, Reedy M3 17.5, MCG Reaper 7.5, Savox, Blue Bird.
Onyx Charger.
Favorite Tire: JC Blue Dirtwebs, and maaaybe Pro-line Primes.
Onyx Charger.
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: RC10 Shock Bind
If the piston is sticking and it didn't before, it's most likely a slightly bent shock shaft. If it binds just due to the orings then a drop of oil would free them up.
Re: RC10 Shock Bind
whats the best replacement shaft to match the other one?
Onyx Charger.
Onyx Charger.
Shocking binding problem found???
Okay, so i believe i found the issue with the horrible binding I had. The original piston (it has a notch, not a hole) i believe swelled and is now way to big to even fit. so, i pushed on a modern small bore piston which was very tight to put on, and it seems to fit juust right but with ever so slightly a little gap between piston and shock body. Will this hurt the cars' performance? and what shafts will i need to replace the old ones when i need to. what is the size. Im really hoping to order EVERYTHING tonight. Also, in the original manual, there is this rubber tube, where do i find new ones?
Onyx Charger.
Onyx Charger.
- Been thanked: 81 times
- bully
- Been thanked: 6 times
Re: RC10 Shock Bind
A shock will feel funny until you have filled them with oil.. It's not advisable to run the shock thru it's motion without oil you just ruin the o rings.. Get some o rings and some green slime,it's pretty much compulsory when building any shocks.... The slime is used to coat an protect the o rings an make your shocks last longer before needing rebuilt...
Re: RC10 Shock Bind
the piston was swollen. im serious. The newer small bore fit right in. The older piston was bigger than the hole for shock body.
Onyx Charger.
Onyx Charger.
Re: RC10 Shock Bind
i should be able to do that tomorrow
Onyx Charger.
Onyx Charger.
- 457 Views
Last post by rangerg
- 426 Views
Last post by juicedcoupe
- 598 Views
Last post by MONSTER
- 502 Views
- 701 Views
Last post by gtrgeo
- 1050 Views
Last post by Lonestar
- 504 Views
Last post by railey72
- 1089 Views
