RC10 Shock/Arm Clearance Question
General info, Q&A.
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
When working with the wide RC10 front arms, I often run into clearance issues attempting to install the lower shock mount. My usual solution is to file the arm until there is enough clearance. Is there a better solution?
Thanks, Mark
RC10 Shock Mount.jpg (24.76 KiB) Viewed 1090 times
RC10 Arms.jpg (15.77 KiB) Viewed 1090 times
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: RC10 Shock/Arm Clearance Question
Post by JK Racing »
I usually file or trim just a touch to make it easy. Its a tight fit.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
I haven't run into many issues with the parts you posted. The "flanged" rod ends on the other hand need clearancing.
twisted
Post by twisted »
i used the factory b4 balls. they fit into the stock plastic shock ends. fits perfect in the arm.
limestang
Post by limestang »
Thanks everyone for your suggestions.
Mark
