longer dogbones
orangemazda
Has thanked: 14 times
Been thanked: 60 times
longer dogbones
Post by orangemazda »
As some of you know, I'm building another WOIN car but I'm doing it with a slightly different flavor.
Project thread: http://www.rc10talk.com/viewtopic.php?f=36&t=36923
Anyways, I'd like to use 1/4" rear axles with RC10T bearings in the WOIN rear hubs and Kline A-arms. My question is, has anyone done this and found dogbones that will work?
Why do I want to do this you ask? Freak of nature, that's why... :lol:
Re: longer dogbones
B4 dogbones may work. They are about .400" longer than an rc10 bone.
Been thanked: 3919 times
Re: longer dogbones
I blended the 1/4" outer cva stub axle with a B4 cva shaft on my ten4 short arm car. The only way to get the 1/4" axle is in the classic cva kit so it's not the cheapest route
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: longer dogbones
Post by JK Racing »
What rear wheels are you planning on running (I assume you are attempting to keep it 'legal')? The WOIN formula was to run modern B4 (or now B5) wheels on the rear, but neither of those are designed to use the 1/4" old axles.
Not trying to poopoo the idea, just dont want you to go all the way down that road and have to rethink wheels.
orangemazda
Re: longer dogbones
JK,
I don't really have a good reason that I want to use 1/4" axles and dogbones other then I want something somewhat weird for project "freak of nature".
You are correct that WOIN formula works great, I used it on my WOIN build here: http://www.rc10talk.com/viewtopic.php?f=35&t=36069&start=15
My thought on this project is that this car is mid morph from an oldschool racer to current technology. As if my old Andys racer from the 90's and my current WOIN car had a baby! :lol:
Again, just wanted to do something different and "weird". :D
JK Racing wrote:What rear wheels are you planning on running (I assume you are attempting to keep it 'legal')? The WOIN formula was to run modern B4 (or now B5) wheels on the rear, but neither of those are designed to use the 1/4" old axles.
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Re: longer dogbones
Post by mk-Zero »
Wasn't there a thread a while back that listed all or most of the available cva shafts and their lengths? I could use a list like that too for some projects I have in mind...
JK Racing
Re: longer dogbones
Post by JK Racing »
No issues, just trying to help :)
Now, get that thing all finished up and show us some pics!
Re: longer dogbones
no, there are only bits and pieces through different threads. I would love to get a driveshaft database set up, but it's a pretty monumental task. also, there has to be a standard measurement technique. For whatever reason, most are measured end to end when the pin to pin in the critical length, as well as ball diameter. even the manufacturers are all over the place.
the other problem is guys will only have certain models/brands, and you have to rely on everyone measuring to do an accurate job. Not always the easiest. especially for the oddball brands.
n20capri
Re: longer dogbones
Post by n20capri »
I couldn't find any measurements when I was building my OIN car - so I made my own to the exact specs that I needed and had them 3d printed out of stainless! So far they are working fine. The car has been 69mph with them! lol
They are 2.7" pin to pin - can be customized though...
https://www.shapeways.com/product/ZS99YYX2Q/2-7-quot-dog-bones?li=shop-results&optionId=55931261
mk-Zero
Business Member
Re: longer dogbones
Post by mk-Zero »
Nice work, glad to hear they're holding up. I would be more concerned about them holding up to a high traction off road car than on a top speed car though.
n20capri
Re: longer dogbones
Post by n20capri »
mk-Zero wrote:Nice work, glad to hear they're holding up. I would be more concerned about them holding up to a high traction off road car than on a top speed car though.
I did do some pretty good launches on them...granted only a few but I was surprised for sure! lol.
mk-Zero
Business Member
Re: longer dogbones
Post by mk-Zero »
Cool, I may have to try some! Would be awesome if we had totally customizable bones that could hold up to abuse on the track!
mk-Zero
Business Member
Re: longer dogbones
Post by mk-Zero »
Have you tried to make cva bones? I would think the cva end would be the challenge as far as strength and precision?
n20capri
Re: longer dogbones
Post by n20capri »
I don't have any CV stuff to copy - just plain bones. If I had something to copy I'd give it a shot...
mk-Zero
Business Member
Re: longer dogbones
Post by mk-Zero »
Maybe I'll give it a try, it would be fun :P
I'm pretty sure they will not hold up though. The walls are pretty thin on the cva end and stock ones seem to be hardened. I tried to drill one once and it was obviously very hard material. A cvd on the other hand would probably print well and stand up to abuse fine...
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
