Besides the obvious ease of finding wheels, is there a reason to pursue a front hex swap for my B2 & T3?
Also, is it true the B4.2 caster blocks will fit the arms on the B2 & T3?
if not what needs to be modified for them to work? \
thanks
Hex upgrade for B2 & T3
- Has thanked: 3 times
- Been thanked: 10 times
Re: Hex upgrade for B2 & T3
Yes u can use the b4 series caster blocks and steering arms to convert to hex, it might change the overall front wheel base a little, not sure what the ROAR max limit is, that may only matter is your racing, the only mod u will need to do is drill out the b4. Caster block hole. You can also use b4 wheels with bearings on the b3, you will need rc10 team car spindles to correct the front end with. Wide gt axles are a little to wide IMO
- 1497 Views
Last post by Jschoenb
- 983 Views
Last post by civilguy
- 1144 Views
Last post by highwayracer
- 1431 Views
Last post by jacsac
- 1626 Views
Last post by Sixtysixdeuce
- 8488 Views
Last post by vinmansbrew
- 810 Views
Last post by Bottom Feeder
- 693 Views
Last post by Frogwagon
Users browsing this forum: Google [Bot] and 2 guests
