HELP optima turbo ?
- Has thanked: 3 times
- Been thanked: 5 times
Re: HELP optima turbo ?
Hi all, use half old diff, ( the one with the gears in) offer up the belt side of the new one you will see its to wide, if you take a sharp knife and cut off the flange up to the step, (sounds complicated but its not) all you have then is a belt pulley, it all screws together, just make sure you line up the two half's correctly, ( the cutouts in the belt pulley line up with the planet gears. Have fun. Take care all.
- tintin74
- Been thanked: 23 times
Thanks for the tip, I will try it out once I am back from Vacation.
Check out http://www.kyosho-optima.com and my Facebook Group https://www.facebook.com/groups/optimaseries/
- Been thanked: 276 times
Looks good...Losi graphite arms? What are your plans for the rear stabilizer? Looks like you'll need to tap or drill holes in the arms.al.48 wrote:Bit more progress, not final, what do you think, spot the rear arms !
- terry.sc
- Has thanked: 6 times
- Been thanked: 75 times
Two main options, the easy one is the Ultima 48dp spur, part number W-0110.al.48 wrote:Hi all, is there an "easy" way to get a 48 dp spur on ? Cheers all
The other option is to use Robinson Racing 48dp Ultima gears, while the spur gears are easier to get hold of you will also have to replace the layshaft with the Robinson Racing 48dp one as well which is a lot harder to find.
Sorry guys, been a while, had problems my partner passed away last week after a long illness, and I'm short of a few bit to finish, but I keep looking, and will post when it's up and running, take care all.
Almost...you'll want to install a bumper before you run it.
- 68 Replies
- 18753 Views
Last post by Garage Hack
- 2165 Views
- 1784 Views
Last post by j0pp3
- 20 Replies
- 2318 Views
- 1136 Views
- 27 Replies
- 7258 Views
- 2182 Views
Last post by Meanee
- 984 Views
