hey guys, in the middle of a resto, a chassis I have has a few scratches on the bottom, and its a bit...dull. any way I can gloss it up (with a hard-wear finish)
not sure if Tamiya clear gloss would do the trick...perhaps not strong enough?
Cheers
gloss for carbon fibre?
Re: gloss for carbon fibre?
sand it with 1000 grit wet sand paper, then use a clear lacour
will be as good as new
ed
ed
Hi, my name is Ed, and im a addict.
To remove fine scratches from CF, I use brass polish, A lot of hard rubbing but it works fine, leaves a shiny surface, do this process in the end, use fine sand paper first to get rid of as much and as rapidly as you can but yeah brass polish works just fine
- DMAT
- Been thanked: 4 times
when I was restoring my graphite chassis. I used the clearcoat that dupont makes. available at autozone. I did use the whole can on the chassis but its effectively protected. I've raced it and normally just bash it and its held up for a year+ now.
I did prep with 3k and 5k albeit you cant really see the results from them.
- DMAT
DMAT wrote:when I was restoring my graphite chassis. I used the clearcoat that duplicolor makes. available at autozone. I did use the whole can on the chassis but its effectively protected. I've raced it and normally just bash it and its held up for a year+ now.
- 1320 Views
Last post by minichamps11
- 1203 Views
Last post by THEYTOOKMYTHUMB
- 25 Replies
- 7181 Views
Last post by Peakey
- 3074 Views
Last post by dldiaz
- 1480 Views
Last post by Jerzi
- 3022 Views
Last post by Peakey
- 444 Views
Last post by Dangeruss
- 29 Replies
- 5487 Views
Last post by HKS_TRD
Users browsing this forum: Google Feedfetcher and 5 guests
