MIP SP1 Ball Raced Diff (BR-100)
I recently picked up a MIP SP1 tranny with a special Ball Raced Diff (BR-100).
After searching everywhere, I can't seem to locate a manual for the Ball Raced Diff. I have the parts diagram, but no instructions - in particular I am trying to find what oil is recommended. The document I have says that it uses oil vs grease for the diff.
If anyone has any detailed information on this diff, please let me know. I may also need some parts - please let me know if you have anything specific for this diff. In particular, I may need BR-5 and/or BR-6 parts.
Thanks as always for your help!
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: MIP SP1 Ball Raced Diff (BR-100)
I found this:
http://www.rc10talk.com/viewtopic.php?f=7&t=651
This is all very interesting!
- Has thanked: 36 times
- Been thanked: 1318 times
Thanks guys..I have those...just wondering if there was something more specific for the BR-100
- jcwrks
- Has thanked: 171 times
- Been thanked: 393 times
A few drops of light oil on the internal gears (some will tell you no oil), clear silicone diff grease in the diff, and black grease on the thrust assembly. They tell you not to use Associated but that can be ignored.
The TX SKUNK
- LurkingCAT
- Has thanked: 202 times
- Been thanked: 271 times
Agree on the standard lubrication for ball diffs - silicone grease on diff and molybdenum grease for the thrust bearing. I've seen three versions of the idler gear - steel, brass and delrin. In my opinion the brass and delrin may run dry (of course you could also lubricate these trains (eg ceramic grease)). In a steel to steel gear connection it might be advisable with some sparse lubrication (eg a PTFE (Teflon) grease). One just have to try to avoid lubricant contamination from gear train to ball diff... So sparse and high viscosity.
- 4059 Views
Last post by NomadRacer
- 2738 Views
Last post by jcwrks
- 1793 Views
Last post by esprit79
- 1901 Views
- 2048 Views
Last post by bscotti
- 5734 Views
Last post by RC10superfan
- 1020 Views
Last post by littleVETTE
- 1630 Views
Last post by Group B
Users browsing this forum: Bing [Bot] and 3 guests
