Will both fit the Pro XL? I see the 614 has a little hole in the shaft. Any other differences?
Also, anyone know if the pinion set screw is 3x3 or 4x4? The manual say different things in different places.
Thanks
Ultima Rear Shaft - Is UT-18 and UM-614 the Same Thing?
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Re: Ultima Rear Shaft - Is UT-18 and UM-614 the Same Thing?
UM 614 is listed as "REAR WHEEL SHAFTS FOR ULTIMA SC/DB" (RB-5/Rb-6 based), so maybe not. You can try, though.
Doesn't the Pro XL use the cone-drive hex washers? If the UM-614 has a hole in it, it must have pin-drive right? And therefore, they wouldn't be the same thing.
- 645 Views
Last post by Snaab9-2
- 733 Views
Last post by mrlexan
- 526 Views
Last post by prp
- 1080 Views
Last post by Sparbolt
- 2060 Views
- 1694 Views
Last post by vwjuice
- 1436 Views
- 1235 Views
Last post by tdevilman77
