RC10 B1.5 - #5
- Has thanked: 28 times
- Been thanked: 946 times
Re: RC10 B1.5 - #5
The B1.5.1+5.5M
A name just as bad as every new car on the market.
Edit:. Forgot to put the "M" on the end..... For no particular reason.
Re: RC10 B1.5 - #5
Fabbed up a brace for the new B1.5.1+5M tub. I still have to trim it down and give it some shape, but it's attached to the tub and motor plate and the rear feels pretty solid.
Re: RC10 B1.5 - #5
Alright, the brace is done. It's wider than the stock T2 motor guard, but I tried to mimic the shape. and added a few slots too.
Re: RC10 B1.5 - #5
The trans and bulkhead were easy. Just made a template, spun it around and drilled the new holes.
the part that sucked was having to add 2 new arm mount holes to the tub. You can't move the mount front and back on the T2 tub like the rc10. Because the hub carrier is set back on the arm in relation to the mount, the mount needs to move back on the tub in a mid motor setup. So it requires a new hole behind the front arm mount hole so the mount can be moved back. I used a stealth trans drill template to do that. But I boogered the one hole up when countersinking it, so I hope it doesn't cause me problem. I may have it welded up so i can redo it.
- klavy69
- Moderator
- Has thanked: 544 times
- Been thanked: 255 times
Re: RC10 B1.5 - #5
just a tad different from before to after
Looks great though. Finally have a nice runner...congrats
Re: RC10 B1.5 - #5
Gonna take it to the track and try it out tomorrow. I was fairly happy with it before, but I think it'll be a little quicker now...... I hope.
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Re: RC10 B1.5 - #5
That brace looks awesome with the slots
I do have some concerns about that gold nose plate though.... hey, at least it matches the motor endbell
Let us know how it works at the track
Re: RC10 B1.5 - #5
I actually had the gold plate on it before, when I decided to use these particular front arms. I swapped it out for a black rere nose though. But with the alterations at the front, I would have had to drill and tap a new hole in the nose and didn't want to do it to that one. This gold one is new, but had been cut up a bit when i got it. So I didn't feel bad drilling a hole in it.
Re: RC10 B1.5 - #5
Yeah, it's temporary. In trying to push the servo so far forward the bellcrank arm hit it. So I had to move it back, but the battery box was in the way to move it back more. With the ball stud being so low on the bellcrank a straight one hit the servo when turning. So eventually it'll end up with a rere worlds bellcrank with the taller servo arm. Then a straight one can go back on it.
- RC10th
- Has thanked: 38 times
- Been thanked: 970 times
Re: RC10 B1.5 - #5
It's a bit bent like its owner
The worlds steering is a good move, from your photo it looks like there is plenty of clearance, have you tried a long ball stud with a thick downstop spacer?
I vote for blue ano to pay tribute to Pavidis's T2
- 47 Replies
- 15979 Views
Last post by WebSteve
- 2496 Views
Last post by Beau S
- 1517 Views
- 351 Views
Last post by MBesr25
- 3392 Views
- 678 Views
Last post by SMOKE-DOG
- 93 Replies
- 19545 Views
Last post by Jeep-Power
- 1536 Views
Last post by JosephS
Users browsing this forum: Bing [Bot], DotNetDotCom.org [Bot] and 2 guests
