Andys/S&K Pro Race Arms
- transamman908
- Been thanked: 5 times
I came across these RPM front arms and have not seen any like these before. Did RPM make arms that would be a replacement for the Andys pro race arms? They do not fit a 10T bulkhead but are the same length as the worlds arms and the pro race arms. They do fit the Andys pro race front bulkhead. Here is some pics showing the rpm arms in question compared to a pro race, standard andys, stock AE and a rpm worlds arms.
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Andys/S&K Pro Race Arms
They are truck arms, for monster truck conversion. They made rears as well.
- Has thanked: 1129 times
- Been thanked: 3917 times
- transamman908
Ok thanks! So it seems they could also be used to replace the pro race arms being they are the same length? The only difference I see is the shock mount holes being off by like !/4" or less.
Edit: Actually the rpm arm is about an 1/8 shorter than the pro race but still thinking I could use them on a S&K chassis with a pro race front bulkhead.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
The RPM arms would be short on a Pro-Race front end but maybe you could use GT axles to bring the width back out.
Option #2 is B2 Carpet arms...which are longer than Andy's Pro-Race arms but should work with B4 wheels. Problem with those is the shock mount holes are further out.
Then there's JG Truck arms....which I'm dragging my feet on but will eventually get reproduced. They are as long as the B2 carpet arms but have the shock holes further in. I don't know how well they'd work with B4 wheels though. Might have some rubbing issues like the RPM truck arms.
- 29 Replies
- 4690 Views
- 998 Views
Last post by DaveM
- 2179 Views
Last post by necka
- 545 Views
Last post by klavy69
- 431 Views
Last post by juicedcoupe
- 1878 Views
Last post by jcwrks
- 28 Replies
- 5912 Views
Last post by Speedworm
- 665 Views
Last post by Brandon G
