Ten4: the 4WD RC10 project
Re: 4WD RC10 project
As you know, I am really excited about this.
An extended Turbo Mirage shell will also be on my list.
Great work guys as always.
Dan
Dan
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
Printing a steering block
Done
test fitting with the caster block i printed a couple days ago
Same day turn around printing parts myself is much better than 3 weeks from shapeways for testing and debugging a desing.
Done
Yeah super cool! I've been wanting a 3d printer for some time now but I'm spoiled at how well the shapeways parts look. Yours look decent though! Maybe you can give us some insight on the whole 3d printing process. I read so much on failures and clogs and stuff so I'm curious as to how frustrating it is (or isn't).
-Mike
RC10T | Kyosho Lazer ZX - 55mph | Mid Motor RC10 Pan Car Conversion - 72mph | OIN RC10 spare/used parts build - 69mph | 4x4 MonsterT build
86 ascMcLaren Capri 5.0 | 86 Mustang SVO
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- mk-Zero
- Business Member
I'll start a separate thread on it some time so this one doesn't get cluttered with it.
For now though I'll just say you don't just turn it on and expect it to print perfect parts, there's quite a bit of trial and error, and learning. The other thing, as you pointed out, is that the quality of a home-printed part is probably never going to be as high as what can be done on industrial machines costing on the order of 100x more.
- flipwils11
- Been thanked: 15 times
- mk-Zero
- Business Member
I think I've got the mounting for the front trans case all sorted out. Last night i printed a trans case with mounting bosses on it. Fresh off the printer:
Then tonight i test fit it, it fit great!
The only other change is that I'm going to have a piece sticking down to fill in the gap below the boss on the trans and between the arm mounts, just for better cosmetics.
Next up is the steering, i think I'm going to have to design new bell cranks and modify the steering blocks again. Stay tuned.
- littleVETTE
- Has thanked: 6 times
- mk-Zero
- Business Member
Thanks man!
Yeah, its a huge benefit to be able to test a part within a day or so of designing it. I wish i had had the printer when we started this project, it would have been done by now.
- slotcarrod
- Been thanked: 41 times
Wow, just WOW!
I can only imagine where you are going to go with this printer and your creativity!
Rod Littau
- mk-Zero
- Business Member
I'm down for helping out any way I can...This is what I want to do...mk-Zero wrote:Thanks Rod. Next up is a mid-motor 4WD RC10
-Mike
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- 1277 Views
Last post by DaveM
- 21 Replies
- 4183 Views
Last post by amx73
- 208 Replies
- 17087 Views
Last post by hugger19
- 1428 Views
Last post by mk-Zero
- 4589 Views
Last post by lotus15racer
- 71 Replies
- 12825 Views
Last post by Lavigna
- 27 Replies
- 9506 Views
Last post by Lonestar
- 37 Replies
- 4596 Views
Last post by minimini
