Kyosho Slingshot
- Has thanked: 792 times
- Been thanked: 2264 times
Re: Kyosho Slingshot
Kyosho shorts were called a 3" shock, but not sure if they are measuring eye to eye or ?? If you haven't got an answer I'll try to measure when I am home
Factory Works website
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
It's been a while since I did anything to this. I finally mounted the shocks I got from Dennis and Alex. Thanks guys! I also mounted some spare HPI Vintage wheel sets for the all blacked out look. Now to find a body.
Jeff
The original shocks on mine look like stock Kyosho Gold, bit IIRC, there were spacers on the inside to limit the travel. I bought the kit in Japan, so I can't read the manual to get exact numers.
I think it's been run once in it's life, and has never had a body. I had one, but screwed it up trying to use liquid mask and regular paint.
- Been thanked: 276 times
I've used that trick before to get aftermarket shocks to work for my CYANide car (full onroad conversion of Optima). I used a $23 set of 4 3Racing dampers for the Lazer ZX-5 but they were a bit too long. Short 4.8mm ball-cups and spacers inside the shocks helped me get them just right.Wahrsuul wrote:there were spacers on the inside to limit the travel.
- SFC K
I have the clips that came with the yellow sport shocks. I left them out so the shock springs don't build up memory while it sits on the shelf. I tried looking for the gold shocks to keep it all original looking but the cost is not worth it to me. It would be nice, but I like the look of the yellow on black. I did replace the bottom ball end though with the shorter ones to get the arms level.
Jeff
- 423 Views
Last post by JK Racing
- 2151 Views
Last post by Kyoshojoe
- 449 Views
Last post by ProXL
- 810 Views
Last post by LTO_Dave
- 3441 Views
Last post by tintin74
- 35 Replies
- 1892 Views
- 1519 Views
- 2578 Views
Last post by Lonestar
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DotNetDotCom.org [Bot] and 2 guests
