Mike's mid motor rc10
mikea96
Has thanked: 660 times
Been thanked: 878 times
Post by mikea96 »
Since its going to be awhile until I can get electronics for my team car I'm going to mock up a mid motor car on a spare chassis. :D
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Re: Mike's mid motor rc10
Post by mk-Zero »
8)
slow_jun
Post by slow_jun »
subscribed.
― Confucius
mikea96
Post by mikea96 »
So is there any disadvantage to running the motor in reverse if you dont flip the top shaft
mikea96
Post by mikea96 »
Got a little more done today! Still deciding on what i want to do with the back of the chassis and bracing the chassis.
Stodd16
Post by Stodd16 »
I was just talking with a buddy about doing this. Any reason why you choose to flip the top shaft. All the others are flipped as well but thought if you didn't you could keep the entire motor plate and secure that to the chassis? Love the progress I'll be watching this one
mk-Zero
Business Member
Post by mk-Zero »
Looking good!
I dont think the motors are made to perform well when spinning in reverse. I think the timing would be off... :?:
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Brushed motors are designed to go in one direction but if you use a mod motor you can flip the endbell to run it in reverse.
Unsensored brushless motors don't mind going in reverse but brushless motors with a sensor need a reversable ESC.
You definitely don't want to just flip your controls so forward is reverse and vice versa...or rewire the polarities through your ESC. Your ESC won't really like it. ;)
If you don't want to flip the top shaft you can put an idler gear between the pinion and spur gear. That was a common thing to do right before the 4 gear transmissions started showing up.
The last, and cooler vintage, option though would be to use a Hyperdrive pulley/belt for the pinion and spur. :)
mk-Zero
Business Member
Post by mk-Zero »
BTW, if you have any interest in bracing it like i did mine, I'm thinking about making the mounts i made available from shapeways (in nylon).
mikea96
Post by mikea96 »
I have a milling machine at work so i plan on making something. :D
mikea96
Post by mikea96 »
I reversed the shaft so spur gear and wheels spin in the same direction as I'm not sure how it will run if they are spinning in the opposite direction.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
mikea96 wrote:I reversed the shaft so spur gear and wheels spin in the same direction as I'm not sure how it will run if they are spinning in the opposite direction.
and you did the right thing...
mikea96
Post by mikea96 »
That is what I was thinking.
Lonestar
Post by Lonestar »
most mid-motors today run 4-gear ("MM4") trannies to still load the rear tires... with MM3, you end up getting A LOT of front end ;)
good read HERE: http://www.team-durango.com/blog/2011/12/06/dex210-motor-configurations/
Paul
mikea96
Post by mikea96 »
That was a great article thanks Paul!
Users browsing this forum: No User AvatarTbot [Bot] and 6 guests
