TRX1 rear suspension arm mount
- peuge73
- Has thanked: 5 times
Hey guys.
For those who are running TRX1: do you use 0° (2797) or 1° (2798) for rear suspension mounts ?
Also, what about the amount of caster shims in the rear side (1934) ?
Specially for slippery and dusty tracks.
Thx,
Hugues
Thx,
Hugues
local club president, but also family team manager - mecanic - official sponsor, and some times cruising my RC cars......YES!!!!!!!!!!
http://www.bmvrc.com/
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Re: TRX1 rear suspension arm mount
Check this out. In this directory, you will find the tuning guide portion for the TRX-3. This tuning also applies to TRX-1 as both cars have near identical rear end setups. Hope this helps.
http://www.traxxas.com.ar/temp/
Mark
Mark
- peuge73
Thx for these documents.
Very usefull.
Hugues
Very usefull.
Hugues
- prp
- Been thanked: 13 times
+1 toe in, with 2° of caster
And for the slipper, a little bit if no your burn the slipper
- peuge73
Merci Pierre. Hope I understood everything well.
So adding 1° on toe in in the rear will be done with the optionnal traxxas part 2798 for a total of 4° each side (according to TRX-1-3 documentation).
For rear caster, the std is 3°, and the caster shims are 1,5 and 3°. I will add 1,5° for a total of 4,5°.
I noticed also your slipper recommendation.
- prp
Sorry I don't remember the rear arm have toe in.
I don't have the tuning guide, you can mount like the notice
the best set up for start.
-On slippery track, put more toe in
-On very bumpy track more caster
-On flat track without jump no caster
And for the slipper , Watch this:
https://www.youtube.com/watch?v=vPGOOhRe8mQ
[youtube]vPGOOhRe8mQ[/youtube]
Reason: fixed youtube link
- 1733 Views
Last post by madracer 1
- 1329 Views
Last post by RRD
- 1174 Views
Last post by RcMonk
- 796 Views
Last post by fleetwood472
- 29 Replies
- 3501 Views
Last post by JK Racing
- 694 Views
Last post by littleVETTE
- 1104 Views
Last post by Typpo
- 1480 Views
Last post by yellowdatsun
Yandex [Bot] and 5 guests
