using up some odd bits....with Grizzly results!
- Has thanked: 1129 times
- Been thanked: 3919 times
What do ya get when you have a chassis cut too short, some random towers, and 5 big grizzly tires laying around? Well...you get a short wheelbase mid motor short arm monster truck lol.
If you have to ask why, your not as drunk as I!
hey, that rhymes lol
More to come!
More to come!
- Minisforever
Re: using up some odd bits....with Grizzly results!
That's pretty cool! Creativity and blood alcohol level always seem to spike together!
keep those projects coming!
I will add, after running a couple packs thru it...its actually quite stable. Wheelies on very high traction surfaces from a dead stop or reverse of course, but otherwise it just gets "light". Jumps awesome too! I figured short wheelbase would be tailheavy, it is flat as can be in the air
I dont have anyone to video right now, but Ill get some video at some point I promise.
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
LOL! That is pretty cool looking! So I bet your turning radius is that of a air craft carrier.
I did not realize you were a poet too.
Jeff
B44 front wheel hexes are perfect and slide right onto 3/16 rear axles. Front isT4.2 with the same b44 adapters.
That looks like fun. Now it needs some tube bumpers and maybe some lights. Might even be cool with a roll cage under the body and maybe a wheelie bar for some catwalks.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Cool, just 12mm hexes? I was thinking you'd need axle extensions like with Blackfoot wheels.gomachv wrote:B44 front wheel hexes are perfect and slide right onto 3/16 rear axles. Front isT4.2 with the same b44 adapters.
Nope they are a shallow hub wheel. I have three more....maybe a trike next lol!
Not 12mm tho, these are like 10mm or so. 12 would have been too easy! It's whatever b44 fronts are
- Has thanked: 25 times
- Been thanked: 143 times
ya my grizzly has a lot of push when it turns. but super fun, just dont go over any large bumps lolgomachv wrote:It turns better than the grizzly
- 5970 Views
Last post by Crazydeath
- 2272 Views
Last post by HENSLO
- 461 Views
Last post by Seabass
- 1264 Views
Last post by YZ-10
- 1122 Views
Last post by cyclepsych0
- 2001 Views
Last post by shodog
- 32 Replies
- 13790 Views
Last post by Synergy
- 1269 Views
Last post by Welshy40
