My mid engine rc10gt - sorry to say but its sold
integra22t
Post by integra22t »
ive been thinking about doing a mid engine rc10t3 but a rc10gt fell into my lap so im going to build it and see how diffrent it will handle to the rear motor rc10t3
the bad part ...2 bent front shock shafts , and it needs a set of diff rings and balls
going to order the parts soon as well as a tc5 motor mount .. looks like a fun project
integra22t
Re: My mid engine rc10gt
just made sure the chassy was strait .. it wasnt but is now :)
i thought the bottom was crappy looking and would replace the chassy but want to make sure the truck will be good before i make a custom chassy for it .. so i just whent and polished it instead
its not a perfect polish but seeing its a runner .. good enough
romulus22
Has thanked: 885 times
Been thanked: 768 times
Post by romulus22 »
Don't you mean "mid motor" :wink:
Just kidding, look forward to watching your progress.
integra22t
lol i thought and engine was a motor :lol:
just ordered some part and will be here next week :roll:
Irio - esos
Post by Irio - esos »
Thats interesting, how did you polish it? By hand, dremel?
integra22t
at the shop i work at we have air powered die grinders and have come up with a good steps
the chassy was scatched up so i cleaned it up with a red pad about 80 grit
if you want a smooth polished finish then i do a wet sand with sanding disks on the die grinders ( it gets realy messy ) 180,320,400,600,800,1000 checking between to see if you can see and past scaches .. at this point you have to keep things clean because if some dust plows up and you polish you will scatch the finish and you have to step back in grit
at this point it will look realy good so i finish with a buffer pad and Autosol and it comes out perfect
Irio - esos
Ah, cool. Ive got an air grinder, ill have to try that.
integra22t
got to work on the truck alittle today and got some of it back together
i have some ofna 16mm shocks im going to install on it ... boy they are big compared to the stock shacks
but they do look good on it
just throu the parts on quick and i think this is how its going to end up .. i dont want to have the battery sidewase unless i have to
RC10Eh  It’s my birthday!
Post by RC10Eh »
You were supposed to drop off that urine sample to your parole officer last week ! Looking god buddy .
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Post by mk-Zero »
Nice progress. Man, those shocks are HUGE!
SFC K
Has thanked: 47 times
Been thanked: 9 times
Post by SFC K »
Nice work so far! Those shocks are huge. :shock: This should be an interesting once completed.
Jeff
integra22t
worked on the truck alittle today .. got the gt5 motor mont but didnt realy care for the look so i got out a spair b4 motor plate and 2of the 3 bolts lined up .. just need to make some 7mm spacer for the back of the plate and open up the hole for the slipper
i like the way it looks
i also picked up parts to rebuild the diff but ended up witht he wrong diff rings :oops:
mk-Zero
Business Member
Post by mk-Zero »
Looking good, that's gonna be pretty sweet 8)
integra22t
got the spacers for the motor plate cut today ( 7mm) as well as the center hole opened (1/2") up and the 3rd hole drilled and tapped
i can space the motor another 6mm to the right if i need to for weight ballance but with the battery on that side i might have to move it to the left .. time will tell
sschering
Post by sschering »
Are you going to use the stock GT slipper? That's my plan...
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 7 guests
