B1M
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
B1M
Post by mk-Zero »
So, i haven't been very happy with my gold pan lately, frankly i just haven't been enjoying driving it at the track. It just seems unpredictable, and doesn't respond well to setup changes. Especially compared to my b44, which is so much fun to drive, so stable and predictable.
That being the case, i decided to take a break from it, and tare it down and go through it, piece by piece.
Among other things, the motor plate is tweaked, I've straightened several times already but it seems to always get mangled...
I've been wanting to do a mid motor car for a while, but had planned on getting a donor car to convert. But after evaluating the condition of this car, i decided it wouldn't be any great loss to the universe to use it as the basis for a mid motor conversion. The pan is pretty scraped up
So with that, here's the first mockup. Im not sure at this point if I'm going to add an external 4th gear, or just flip the top shaft and run it with 3 gears. Its interesting that AE just released a 3 gear conversion for the B5M. Other that that, ive got some ideas on how i will brace the chassis to make up for cutting it to clear the motor and for the fact that the chassis wont be bolted to the bulkhead sides. The other potential challenge is rear shock alignment, depending on where i mount the bulkhead. Worst case is i can run some spacers between the shocks and a arms.
Now that I've got a mill, modifying and making parts won't be an issue, so this should be a fun project.
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Re: B1M
Post by TRX-1-3 »
Neat
RC104ever
Re: B1M
Post by RC104ever »
I like it! Looking forward to seeing your progress (so I can maybe copy it some day!!!)
- Chris
Lots of cars...so many cars
janaya
Re: B1M
Post by janaya »
It's shaping up to be a nice build.
Javier -
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Last night I made a little progress. I decided for now to do it as a 3 gear setup. I removed the end of the motor plate since I'm going to need to flip it around. Basically, I masked tangent to the curve on each side of the area I wanted to remove so there would be a nice transition. Then I clamped it in my mill and followed the tape lines. Eventually I'll hit the whole edge with a dremmel/sanding drum so the whole edge is silver. I'll do the same to the pan so they match. I also removed the cap from the one side of the trans case and flipped the input shaft and diff around.
Test fitting in the car. Plenty of room with the shortie pack.
I also figured out how I'm going to brace the rear of the car, should look pretty sweet and work well, stay tuned :wink:
Re: B1M
most mid conversions will tie in to the transmission and chassis right behind the battery with a bracket of some fashion, you can extend it to also include the rear bulkhead as well.
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Thanks. I've got something else in mind though 8)
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Last night I bolted the tub to the mill and milled of just enough of the left side rear for the motor to clear. For now it's just cut off square, as you can see, but I'll figure out how I can coutounr it to make it look a little better. For symmetry I'll probably do the same to the other side. I'm pretty happy with how this is looking so far.
Seabass
Business Member
Re: B1M
Post by Seabass »
Very nice conversion, in fact you are giving me some ides. Keep up the progress.
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Thanks Jake
I like how your CF brace is so visible with it set up like this, looks sweet 8)
I'm gonna need to have you make a custom CF battery brace for me at some point too. I'll design it up and send you the file.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: B1M
Post by JK Racing »
Looks good Brian, we need to get our routine back on, I have cars to test/tune...
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
JK Racing wrote:Looks good Brian, we need to get our routine back on, I have cars to test/tune...
Thanks Joey. I'm still out every thursday night, usually from about 8 till 11-something
I'm lovin' the new layout at LRH, btw
n20capri
Re: B1M
Post by n20capri »
This is so cool. Can't wait to see more.
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Thanks, glad you like it 8)
I've only been working on it for a few days but its really been a fun project so far. I've got lots of ideas for this project, stay tuned :wink:
mk-Zero
Business Member
Re: B1M
Post by mk-Zero »
Got the pan drilled out for the bulkhead and trans. The rear of the chassis is total Swiss cheese now, since it was already drilled for a stealth. I think the strength will still be adequate though. Especially with how I'm going to brace the rear of the chassis.
Test fitting the bulkhead and trans mounting
i also made a bracket for the end of the battery strap. I'm going to have Jake (if he can squeeze it in between all the NIX91 parts) make a shortened version of the CF strap i have now.
Users browsing this forum: No User AvatarTbot [Bot] and 4 guests
