NIX91 Runner - Mark Westerfield
- Has thanked: 11 times
- Been thanked: 24 times
Re: NIX91 Runner - Mark Westerfield
27mm front, 25mm rear.
Anyway you could make a sweet editable .pdf setup sheet? (add a inside camber link hole on the front shock tower)
- Niki
- Has thanked: 3 times
- Been thanked: 36 times
My last outdoor test run was 25mm/25mm.
NIXconcepts -Shapeways Shop- -I.materialise Shop-
--- Quadra-symmetric RC10 --- RC10 '91 Worlds Conversion --- Start of NIX91 story...
Mark Westerfield wrote:27mm front, 25mm rear.
hummm
that's something I could do easy enough
Niki/Jake, would you be able to export the key suspension points like this b4 one as jpgs ? http://www.teamassociated.com/pdf/cars_and_trucks/RC10B4.2/setup_sheets/B4-2_Munday_KeilorCupMLL_2013.pdf
from there I can make a editable pdf with the pics
ed
Hi, my name is Ed, and im a addict.
- Niki
I can do the jpg's. I'll PM you when I get something useful done.
Second run with a couple of setup changes, and a better driver...
[youtube]xII2MoPefzA[/youtube]
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
nice it rotates really hard off-throttle. Are these the hot rear tires for that track?
The tires on the car are Pro-line Electrons M4 with AKA closed cell inserts rear, Pro-line 8175 Rib M4 with standard inserts in the front.
- Lonestar
er... ok. I happen to NOT know what works at your track so you'll have to enlighten me are they supposed to be the hot ticket there? because the car's seems to be really, really skittery... the driver seems to know his stuff, and still he loses the rear end every so often. Or the car was really designed for Masami's fingers?Mark Westerfield wrote:The tires on the car are Pro-line Electrons M4 with AKA closed cell inserts rear, Pro-line 8175 Rib M4 with standard inserts in the front.
Paul
Pro-line Electrons or Suburbs in M4 compound on all four's is the popular tire. The track was a practice day (a little dusty, no race groove). And there was no traction compound on the tires. That back section is a steep downhill where he spun the rear end out a couple of times using too much brakes. Otherwise, the car is pretty balanced and easy to drive. Holeshots grip more but push a little too much exiting the corner.
- jbmeyer13
- Has thanked: 25 times
- Been thanked: 11 times
Overall, how does it compare to a modern B4/B5?Mark Westerfield wrote:Pro-line Electrons or Suburbs in M4 compound on all four's is the popular tire. The track was a practice day (a little dusty, no race groove). And there was no traction compound on the tires. That back section is a steep downhill where he spun the rear end out a couple of times using too much brakes. Otherwise, the car is pretty balanced and easy to drive. Holeshots grip more but push a little too much exiting the corner.
The guy driving my car in the video, Kyle Rhodes, has a fast lap of 16.1 with his mid-motor B5. He got a fast lap of 16.5 with the Stealth. Not bad for the first adjustments on the car.
- jbmeyer13
Wow- that is pretty close. Assuming the avg. lap times for a heat are comparable that's pretty good. B5M has an advantage on high bite tracks (which it looks like that track would normally be) so an even better comparison would be to a standard B5.Mark Westerfield wrote:The guy driving my car in the video, Kyle Rhodes, has a fast lap of 16.1 with his mid-motor B5. He got a fast lap of 16.5 with the Stealth. Not bad for the first adjustments on the car.
- Niki
Good looking track and driving. My friend told me also that car is really easy to drive.
I can see similar rear end bouncing like my own test drive with standard rear arms. Arm flex is not a huge problem in front as shock is in the middle of arm but rear arm will twist as shock is mounted an the edge of arm. It's like one extra undampened spring. Can't be a good thing.
I have "race" arms mounted now in my car and will get to indoor track with it tomorrow. I'll try to shoot some good video material...
-Niki-
-Niki-
- 723 Views
Last post by duckhead
- 989 Views
Last post by Mark Westerfield
- 439 Replies
- 53415 Views
Last post by XLR8
- 3993 Views
Last post by DMAT
- 45 Replies
- 13691 Views
Last post by Niki
- 3915 Views
- 35 Replies
- 11629 Views
Last post by Lurker
- 1992 Views
Last post by TRX-1-3
Users browsing this forum: Facebook [Bot] and 0 guests
