Ok! here is my question:
I have an uncut Pro-line Mirage SS body. I'm thinking of making a mold of it and redesign the mold "slightly". Like an air scoop for example
Is it possible to (by using the mold) massage the uncut buggy body with a heat gun to get the modifications transferred back to the body?
Lexan body massage
Re: Lexan body massage
In theory that should work the issue may be once you start heating the plastic you start relieving any stored stress which could alter the shape. The other potential problem is that the plasitc may be already stretched to the point that any more deformation may tear. Lexan also absorbs moisture so to prevent any bubbles from forming the body needs to be held at temp for a duration of time to remove moisture.
- slotcarrod
- Been thanked: 45 times
Make a scoop out of styrene, glue in place, make new mold.
Rod Littau
- 1934 Views
Last post by LuckyT2
- 1348 Views
Last post by JK Racing
- 1378 Views
Last post by CruzinCustomz
- 756 Views
Last post by templeofspeed
- 1595 Views
- 1774 Views
Last post by DerbyDan
- 38 Replies
- 3907 Views
Last post by Frankentruck
- 1258 Views
Last post by airdreams1
