Since most sensored systems only spin one way and most competition ESC's don't allow you to change motor rotation - what would happen if you swapped A and C and wired the sensor cable backwards?
I assume the timing would be backwards/retarded and hurt performance.
Has anyone tried this?
Interesting brushless thought?
- RC10th
- Has thanked: 50 times
- Been thanked: 1492 times
- DarthRacer
Re: Interesting brushless thought?
If you swap A and C the motor will run backwards. It works OK with sensorless but I haven't tried it with a sensored setup.
TC4 Drifter
TC6.1 USVTA
SC10
RC10 gold tub 6 gear X3
TC6.1 USVTA
SC10
- terry.sc
- Has thanked: 7 times
- Been thanked: 122 times
If the motor timing is set to zero and the A and C sensor wires in the sensor lead are swapped over, then the motor will run backwards the same way it would run forwards. The only problem is that not all motors will give you true zero timing, and if you reverse the wiring just like with brushed you would have less power and higher current draw unless you put lots of timing on the ESC to compensate.
- 1721 Views
Last post by mrlexan
- 925 Views
Last post by tudor39
- 1926 Views
Last post by Kyoshojoe
- 1438 Views
Last post by Diggley
- 29 Replies
- 1620 Views
Last post by rc10johnny
- 1105 Views
Last post by SteveK
- 2329 Views
Last post by radioactivity
- 610 Views
Last post by Bongo Fury
Users browsing this forum: Seznam [Bot] and 4 guests
