i need some help
- Has thanked: 24 times
- Been thanked: 140 times
i need some help
i cant open the pdf file on the traxxas forum to look at the traxxas wildcat manual. can someone on here go to the traxxas forum and than type in traxxas wildcat manual and download maybe on here??? i just need the page on mounting the front shock tower and shocks thanks. or if someone could download it than send it to me in an email?? thanks again. mike
- Been thanked: 325 times
Re: i need some help
I could help, but I'm not getting far bumbling around the site. Got a link to get someone started in the right direction?hugger19 wrote:i cant open the pdf file on the traxxas forum to look at the traxxas wildcat manual. can someone on here go to the traxxas forum and than type in traxxas wildcat manual and download maybe on here??? i just need the page on mounting the front shock tower and shocks thanks. or if someone could download it than send it to me in an email?? thanks again. mike
- terry.sc
- Has thanked: 7 times
- Been thanked: 141 times
Here's the pdf manual to try, checked it out and it works fine:
https://dl.dropboxusercontent.com/u/76796829/traxxas_wildcat_manual.pdf
- Has thanked: 1106 times
- Been thanked: 3806 times
So... Just this?
- Attachments
- image.jpg (48.32 KiB) Viewed 479 times
i guess i have a issue with my comp still cant download itterry.sc wrote:Here's the pdf manual to try, checked it out and it works fine:
hugger19 wrote:ya and the front shock install. i think traxxas uses a weird pivot pin to mount the front shocks.
- Attachments
- image.jpg (54.02 KiB) Viewed 472 times
- j-sou
Maybe not all that helpful, but if you're trying to view the page/pdf in your browser and it's not loading correctly, hold shift and hit the refresh button. Might be a prob with your browser and/or add-ons. Shift refresh should bypass that
Or right-click the link of the PDF file and "Save target as", which bypasses your browser trying to load a PDF file inside itself and allows you to save it to your hard drive. Browsers were never meant to open PDFs, as PDFs are created by Adobe; Adobe Reader is the correct application to open PDFs, but for some reason, the default when you install Reader is to install a browser plugin to force PDFs to display in your browser.
DotNetDotCom.org [Bot] and 12 guests
