So,
I don't remember the A&L setup rubbing and raising / bowing out the "driver's side" nose portion of the original (TBG repro in this case) TRX-1 body when making a right turn. But that is what is going on. I know there is a way to remedy this. But it may involve drilling some new servo mount holes and or flip-flopping the bellcrank arm to the inboard side. Anybody got some insight or should I just go back to the stock steering setup? And is there a bb option with the stock setup? Jeez.
Thanks man,
Mark
Bellcrank to body clearance: TRX-1
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Bellcrank to body clearance: TRX-1
Hi MarkTRX-1-3 wrote:So,
Thanks man,
Mark
the stock setup rubs the body too. I've had to heat up the lexan to reshape it slightly so it clears.
you can use BB in the stock setup - you need to use FHS screws as steering post and put the bearings directly on them - the inner size of the bearing has to match the screw size (M3 I'd think) then the outer size is the same size as the steering bellcrank inner size. I don't have the dimensions handy, sorry. But I use this setup on my trx runner and so far it's withstand (moderate) abuse
Paul
- 703 Views
Last post by mrlexan
- 967 Views
Last post by TRX-1-3
- 973 Views
Last post by jeff93063
- 1076 Views
Last post by RC10resto
- 1335 Views
- 38 Replies
- 5031 Views
Last post by paul1600
- 1099 Views
Last post by limestang
- 3306 Views
