Every year I've looked into attending I was sure it was blinky too.Brandon G wrote:Boost in your 2WD buggy? I thought the general rule of thumb in the classes running 17.5 was to do without it.
TEAM TEKIN 2014 VINTAGE OFFROAD NATIONALS • SEPT 5-7TH
Re: TEAM TEKIN 2014 VINTAGE OFFROAD NATIONALS • SEPT 5-7TH
- Brandon G
Erich Reichert wrote:Ed are you not coming this year? But who will win the cars i have to give away?
Don't worry, Rob will be there. Best reserve a kit for him... lol
So I'm trying to charge up my 3800 and 4000 mah, 7.4V/2S lipos for the first time before the race and not sure what to do/how to cycle them so I figured I'd ask rather then risk a leak/explosion. I never used lipos before. I'm using a new Imex balance charger that can charge any type of battery and I double checked my settings. I've had the batteries for a few years, never used them or ran a charge through them but when I hooked them up to the car the motor ran full speed (but no steering...?). I tried discharging the 3800 mah for an hour but the voltage was still reading 7.35-7.38 the entire time. Does it take longer than that to discharge? Should I discharge them fully and then charge them again? Am I doing something wrong? Thanks.
- stickboy007
- Been thanked: 17 times
Charlie don't surf wrote:Every year I've looked into attending I was sure it was blinky too.Brandon G wrote:Boost in your 2WD buggy? I thought the general rule of thumb in the classes running 17.5 was to do without it.
It says on the first page that electronics are open. I can run just as fine without boost, but if it's allowed, I'd like to try it and see how it goes. Just something new to play around with...
- Regular Member
Don't ever fully discharge a lipo. it will destroy the cell! The 2S lipo should be stored at a voltage around 7.5 volts. If you are getting full throttle with no transmitter throttle it sounds like an ESC problem. Like no throttle input from the receiver or a blown ESC from plugging in the battery backwards. reversing the input polarity from the battery will fry the internal circuit in the speed control.R/Cat wrote:So I'm trying to charge up my 3800 and 4000 mah, 7.4V/2S lipos for the first time before the race and not sure what to do/how to cycle them so I figured I'd ask rather then risk a leak/explosion. I never used lipos before. I'm using a new Imex balance charger that can charge any type of battery and I double checked my settings. I've had the batteries for a few years, never used them or ran a charge through them but when I hooked them up to the car the motor ran full speed (but no steering...?). I tried discharging the 3800 mah for an hour but the voltage was still reading 7.35-7.38 the entire time. Does it take longer than that to discharge? Should I discharge them fully and then charge them again? Am I doing something wrong? Thanks.
Thanks, no I have full throttle control and ESC is working fine I just meant that the battery seems fully charged even though I've had them for a couple of years and never charged them but that's probably because they have 7.35-7.38v stored in them. Perhaps I'm not use to the power increase from a Lipo pack either and that's why it seems fully charged when it really isn't. If storage volts should be around 7.5v and mine are at almost 7.4v it sound like I don't have to discharge and can simply charge them up. Is that correct?jberlenbach wrote:Don't ever fully discharge a lipo. it will destroy the cell! The 2S lipo should be stored at a voltage around 7.5 volts. If you are getting full throttle with no transmitter throttle it sounds like an ESC problem. Like no throttle input from the receiver or a blown ESC from plugging in the battery backwards. reversing the input polarity from the battery will fry the internal circuit in the speed control.R/Cat wrote:So I'm trying to charge up my 3800 and 4000 mah, 7.4V/2S lipos for the first time before the race and not sure what to do/how to cycle them so I figured I'd ask rather then risk a leak/explosion. I never used lipos before. I'm using a new Imex balance charger that can charge any type of battery and I double checked my settings. I've had the batteries for a few years, never used them or ran a charge through them but when I hooked them up to the car the motor ran full speed (but no steering...?). I tried discharging the 3800 mah for an hour but the voltage was still reading 7.35-7.38 the entire time. Does it take longer than that to discharge? Should I discharge them fully and then charge them again? Am I doing something wrong? Thanks.
- Regular Member
Yes, lipos have a lot more power and they hold their charge in storage quite well. I tend to charge mine and then discharge them to 7.5 volts a couple times a year for the packs I don't run on a regular basis.R/Cat wrote:Thanks, no I have full throttle control and ESC is working fine I just meant that the battery seems fully charged even though I've had them for a couple of years and never charged them but that's probably because they have 7.35-7.38v stored in them. Perhaps I'm not use to the power increase from a Lipo pack either and that's why it seems fully charged when it really isn't. If storage volts should be around 7.5v and mine are at almost 7.4v it sound like I don't have to discharge and can simply charge them up. Is that correct?jberlenbach wrote:Don't ever fully discharge a lipo. it will destroy the cell! The 2S lipo should be stored at a voltage around 7.5 volts. If you are getting full throttle with no transmitter throttle it sounds like an ESC problem. Like no throttle input from the receiver or a blown ESC from plugging in the battery backwards. reversing the input polarity from the battery will fry the internal circuit in the speed control.R/Cat wrote:So I'm trying to charge up my 3800 and 4000 mah, 7.4V/2S lipos for the first time before the race and not sure what to do/how to cycle them so I figured I'd ask rather then risk a leak/explosion. I never used lipos before. I'm using a new Imex balance charger that can charge any type of battery and I double checked my settings. I've had the batteries for a few years, never used them or ran a charge through them but when I hooked them up to the car the motor ran full speed (but no steering...?). I tried discharging the 3800 mah for an hour but the voltage was still reading 7.35-7.38 the entire time. Does it take longer than that to discharge? Should I discharge them fully and then charge them again? Am I doing something wrong? Thanks.
Thanks, no I have full throttle control and ESC is working fine I just meant that the battery seems fully charged even though I've had them for a couple of years and never charged them but that's probably because they have 7.35-7.38v stored in them. Perhaps I'm not use to the power increase from a Lipo pack either and that's why it seems fully charged when it really isn't. If storage volts should be around 7.5v and mine are at almost 7.4v it sound like I don't have to discharge and can simply charge them up. Is that correct?[/quote]
Yes, lipos have a lot more power and they hold their charge in storage quite well. I tend to charge mine and then discharge them to 7.5 volts a couple times a year for the packs I don't run on a regular basis.[/quote]
OK, great. I'm going to charge them today and see what happens. If they start at 7.4v what can I expect it to go up to when completely charged and how long will the charge take? Also, I've been watching some youtube videos on balance charging (balancing the cells) and hearing different things. Some say to balance-charge every charge while others say only balance-charge every 4-5 charges. It doesn't seem like the cells have to be balanced EVERY charge but what do you think?
- Regular Member
Yes, lipos have a lot more power and they hold their charge in storage quite well. I tend to charge mine and then discharge them to 7.5 volts a couple times a year for the packs I don't run on a regular basis.[/quote]R/Cat wrote:Thanks, no I have full throttle control and ESC is working fine I just meant that the battery seems fully charged even though I've had them for a couple of years and never charged them but that's probably because they have 7.35-7.38v stored in them. Perhaps I'm not use to the power increase from a Lipo pack either and that's why it seems fully charged when it really isn't. If storage volts should be around 7.5v and mine are at almost 7.4v it sound like I don't have to discharge and can simply charge them up. Is that correct?
OK, great. I'm going to charge them today and see what happens. If they start at 7.4v what can I expect it to go up to when completely charged and how long will the charge take? Also, I've been watching some youtube videos on balance charging (balancing the cells) and hearing different things. Some say to balance-charge every charge while others say only balance-charge every 4-5 charges. It doesn't seem like the cells have to be balanced EVERY charge but what do you think?[/quote]
they should finish charging at 8.4 volts. balancing once a week is fine
I'm sorry if this has been answered somewhere else, but what time does the track close on Friday and open for practice on Saturday? I know that it normally closes at 7 on Friday and opens at 10 on Saturday. Are there special event hours, or will it be normal time?
85Edinger wrote:I'm sorry if this has been answered somewhere else, but what time does the track close on Friday and open for practice on Saturday? I know that it normally closes at 7 on Friday and opens at 10 on Saturday. Are there special event hours, or will it be normal time?
A couple of us asked and Erich's in the process of checking/confirming times. I've copied/pasted a portion of what Wolcott has on their website below which I assume is accurate and up to date until or unless I hear otherwise from Erich.
"Current Hours are Monday closed, Tuesday 12-6, Wednesday 12-7, Thursday 12-7, Friday 12-9, Saturday 10-5, Sunday 10-5
We currently Run off-road on Tuesday night starting at 7, Friday night starting at 7, and Sunday starting at 11am."
naw, it's always been open.Charlie don't surf wrote:Every year I've looked into attending I was sure it was blinky too.Brandon G wrote:Boost in your 2WD buggy? I thought the general rule of thumb in the classes running 17.5 was to do without it.
i got my rc10 ready over the weekend. as well as my race clod, stadium blitzer and my boy's grasshopper. lol
i want to see how silly a hopper with 2.2's looks going around the track. i also took out the 380 and put in a 540 for him, he thinks it's the fastest thing in the world now.
- Has thanked: 13 times
- Been thanked: 14 times
Good luck on the weekend fellas, have a great race. I hope theres plenty of great vids put up of the action
here in Australia our vintage festival is only a few weeks away
Cheers
Mikey
Cheers
Mikey
- Hcp22
- Has thanked: 33 times
- Been thanked: 16 times
Good luck guys, hopefully I will see you next year.
- 311 Replies
- 38829 Views
Last post by Erich Reichert
- 41 Replies
- 16112 Views
Last post by R/Cat
- 192 Replies
- 22344 Views
- 448 Replies
- 35433 Views
Last post by MelvinsArmy
- 222 Replies
- 24275 Views
Last post by tecnica2001
- 321 Replies
- 27379 Views
Last post by tazz888
- 4272 Views
- 22 Replies
- 1721 Views
Last post by Chemical
