Solution to Stealth meshing issue
jfive
Post by jfive »
Hi everyone,
My RC10 rere worlds car have meshing issue just like most of you guys. I've tried all methods of sanding down the idler,
running in etc.......i realise there is no way i could get it to run the way it should. Then I spoked to a few of my mate who is actively racing in Aust to see if i could find someone to make me a new idler gear. And one of them refered me to a fella in UK. After describing the issues of the stealth gear box and given the specs, he was able to make me a new idler gear. and the result was a miracle! the new idler which fitted perfectly and i dont even have to change ratios. My stealth is now silky smooth.
If your interested, contact:
RWRacing
[email protected]
These will be available from early June.
Here is the pic of the idler gear.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Solution to Stealth meshing issue
Post by Lonestar »
ha - RW :) The long-time masters of the competition spurs and pinions! Good to hear they're jumping in :) :) :)
jfive
Post by jfive »
Lonestar wrote:ha - RW :) The long-time masters of the competition spurs and pinions! Good to hear they're jumping in :) :) :)
Yeah I was told Neil is pretty good and get things done really quick. Indeed he was great to deal with.
woodall01
Post by woodall01 »
The problem also might be a bad transmission case. I sent my transmission to AE for the same reason and they concluded that the case was the issue. It has been replaced and the transmission is on it's way back.
Users browsing this forum: No User AvatarMango and 6 guests
