Got a slightly tired RC b4 kit I'm rebuilding.
What's the correct weight of oil to use rebuilding the ball diff ?
It's going to be used mainly indoors on polished floor/carpet surfaces.
Correct Weight of Oil for ball diff rebuild
- Regular Member
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Correct Weight of Oil for ball diff rebuild
Ball diff or gear diff?
If it's a true ball diff use the supplied grease, white stealth on the diff balls and black on the thrust.
If it's a gear diff (which use oil) I cant comment as I've don't like them and havn't driven a car with one that I've liked yet.
On another note - Welcome to the board.
- Regular Member
Thanks!RC10th wrote:Ball diff or gear diff?
its a 2nd hand kit so no parts supplied with it.
It's a ball diff AFAIK It feels pretty rough if you twist one wheel and hold the other, should they feel rough or smooth when you do this ?
- RC10th
Sounds definately like a ball diff, ball diffs feel crunchy when they are worn and need rebuilding. Ball diffs don't use oil but a special grease.
Pick up these parts and rebuild your diff per the manual.
#7677 Diff rebuild kit
#6591 Stealth Diff Grease
#6588 Black Grease
#6588 Black Grease
- 3737 Views
Last post by kaiser
- 1130 Views
- 47 Replies
- 8863 Views
Last post by KidAgain
- 1781 Views
Last post by CamplinP
- 2855 Views
Last post by coxbros1
- 1171 Views
Last post by threejean
- 2693 Views
Last post by Chewbacca
- 32 Replies
- 4408 Views
Last post by RC10th
