yr-4m2
sdrob
yr-4m2
Post by sdrob »
hello everyone, i recently purchased my first yokomo a yr-4m2 in a bulk lot that has been driven until the belt drives wore out.. i have just purchased the main shaft with belt pulleys and spur gear so the next thing i need to find are the 33tooth pulleys for the ball diffs.. i have searched ebay with no luck so far.. any ideas on places to buy these??? or is there a alternative part
hondaman
Re: yr-4m2
Post by hondaman »
I was looking on Ebay US and found the front one from crc_hobbyshop in Canada.They have several NIP. you can contact them and see if they would ship to you. I don't know of an alternative for the 33-tooth different gears. Hope that helps a bit.
Shawn
crusaderlyf
Re: yr-4m2
Post by crusaderlyf »
You need the part number ZD-503 yz10 33T diff pulley
sdrob
Re: yr-4m2
Post by sdrob »
ok sourced a few more bits but i'm struggling to find ZR-001R front bumper bottom
ZR-001F front bumper top, foam and mounting pins..
has anyone got a car with these bits and is willing to either trace them or take some pictures so that i can reproduce them out of carbon fibre.
any help would be great..
hondaman
Re: yr-4m2
Post by hondaman »
I checked out ebay and found a couple things. I sent you a PM with the listings so you can check them out. If I come across anymore I will let you know. I have a bumper from a YR4 and it looks like the ZR-001 bumper. Here is a pic:
YR-4 Bumper
YR-4 Bumper
YR-4 Bumper
If this is the right bumper, I can scan it later and send it to you.
Shawn
Return to “Yokomo Forum”
Users browsing this forum: No User AvatarFacebook [Bot] and 2 guests
