Schumacher Procat custom front diff hangers
Peakey
Post by Peakey »
I'm looking into getting some of these made and was wondering if anyone would be interested in having a set made at the same time.
This is a 3d drawing of what will be machined out of 4mm 6082 T6 Alloy.
Groomi
Re: Schumacher Procat custom front diff hangers
Post by Groomi »
I might be tempted depending on price.
Would they be bare alloy or anodized?
Using my son as an excuse to relieve my youth. :lol:
https://www.facebook.com/MuzzoomModels
Peakey
Post by Peakey »
He was looking into anodizing as they don't do that in house yet but without they would be around £40 per set depending on how many people I could get together.
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
Would these be tapped (M3) to take a screw in both sides - like the originals are supposed to (albeit with self tappers into the plastic) or would you have a clearance hole all the way through like most of the originals end up with 4No nut & bolts passing through? - I would prefer the former :wink:
Peakey
Post by Peakey »
I did ask for them not to be tapped but now thinking about it that would be the better option and look tidier.
On a side note dan I might have something your looking for let me sought through a big box I recived today and I'll get back to you :wink:
Peakey
Post by Peakey »
Ok they can be tapped that's not a problem but what is there will only be about 2mm if thread so it will hold but for how long and how tight it's not known.
Any thoughts or suggestions are welcome
Groomi
Post by Groomi »
Surely there needs to be a tube between the top and bottom - no problem if bolted all the way through, but if threaded then it would need to be the tube, not the plates?
DerbyDan
Post by DerbyDan »
Yes, I just thought that also... not sure how critical the 'tube' bit is - it must help keep it all square?
Peakey
Post by Peakey »
I've ordered some 17mm pcs brass stand off's the same that Luke used on his to replace the plastic tubes. I bet you could find something similar that is or could be tapped to use as a sort of spacer nut.
I went for the stand off so I can still use original belt tensioner system that's on the front diff housing.
Peakey
Post by Peakey »
I've been looking around and I think I may have the answer in a stud connector. Cheep and stronger than the original plastic spacers. 8)
Here
http://www.fixingsupplies.co.uk/nuts/studding-connectors/m3-studding-connector-bzp.html
A slight modification may be required as they need to be about 17.5mm not 40mm so you can make two out of one even better :D
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
DerbyDan wrote:Yes, I just thought that also... not sure how critical the 'tube' bit is - it must help keep it all square?
The 'tube' parts are what holds the front end together. If just the flat parts are made there is nothing to hold the top deck to the chassis and nothing to clamp the gearbox in place to keep the belt in tension.
Peakey
Post by Peakey »
This is how the end result should be.
This is how I wanted it as to make the front stronger and the tensioner system more affective as the screw is not lost in the soft plastic.
DerbyDan
Post by DerbyDan »
^^Looks good^^
Any idea who made the reds ones - is that on Luke's (Kaszal) car?
@ Terry SC - yes I figured that without the 'tube' part of the moulding on the machined section that you would still need to have the long screw passing all the way through from one side to the other - otherwise, like you say there would be no clamping force to hold the gearbox in place :)
Peakey
Post by Peakey »
I think the ones on Luke's were made by GPM
Has thanked: 1737 times
Been thanked: 1145 times
Peakey wrote:I think the ones on Luke's were made by GPM
GPM made a LOT of ProCat alloy parts..... including these parts (or similar). Although, from memory (not great to rely on), my posts were round, rather than hex....
I used to have heaps of alloy GPM ProCat parts..... all I have left now is a set of blue open and closed bearing housings :cry:
Return to “Schumacher Forum”
