hello everyone, i have a couple of restoration projects going at the moment and need a little help.. i have a optima, turbo optima, ultima sideways and a original ultima.. my question is what is the pinion i need for these.. the manual says a 15tooth but no mention of the pitch..??
i'm also in need of the very expensive spur/centre gear.. are there any other options to replace this gear?? no one making repro parts of these yet???
cheers
optima/ultima pinion
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: optima/ultima pinion
Pitch is 32, and unfortunately no aftermarket currently for the counter gear. One member has modified his motor plate to fit the traxxas cluster gear but it's a different ratio- not sure how it would work for you. Also not sure the gear cover still fits
Link: http://www.rc10talk.com/viewtopic.php?f=30&t=33609&p=364761
thanks for the reply, time to start buying more parts..
quick question tho.... what is the difference between the 3 hole and 6 hole spur/counter gear version 1 and version 2???
definately keen on the traxxis gear, have a modified set of optima plates that i wont use in a resto so might have a play...
- 1837 Views
Last post by RichieRich
- 3506 Views
Last post by nikoscfu
- 2391 Views
Last post by Jirka
- 21 Replies
- 3213 Views
Last post by Bormac
- 66 Replies
- 7742 Views
Last post by Mr. ED
- 1384 Views
Last post by treehugger
- 1074 Views
Last post by tamiyadan
- 2232 Views
Last post by TM Ru22311
Bing [Bot] and 5 guests
