Essential Tools - Please post yours here
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
I thought it would useful to post tools people have found very beneficial to the RC hobby. I'll go first - A recent addition to my tool box is the Dynamite EZ Body Post Marker Set (DYN5145). Great on painted bodies, I tried it out for the first time yesterday, and was able to locate near perfect body post holes on the first try. There are a few tricks to using it, and the rubber plug adapters should be replaced with a plastic insert, but this tool will easily pay for itself.
Hope others find this helpful.
- Limestang
Has thanked: 1134 times
Been thanked: 3930 times
Re: Essential Tools - Please post yours here
Those are nice :mrgreen: keeping with the body mounting theme, a good tapered reamer is a tool you won't ever want to be without once you have used one. Mine is a Hudy, I tried the Dubro and it was junk. The Hudy is pricey but worth it
Been thanked: 506 times
I always used two 4 way wrenches for my cars, instead of a full nut-driver set. I use a tamiya 4 way that I got from my very first grasshopper, and then a 4 way wrench for standard sizes. It was made by trinity, but not sure you can still get them. very good instead of hunting around for the right size.
xacto blade
set of hex ball drivers
good set of tweezers, I come from an electrical/technician background, so I have a really good sturdy precision set with good jaws
good soldering iron
good set of philips head screw drivers. If using metric screws, the JIC size philips heads are a huge benefit.
great set of needle nose pliers.
you can get a lot done with these few items.
Rootdown4594
Post by Rootdown4594 »
those cheap little plastic tools you get with associated kits. I use those more than anything just because you can toss them in your pocket.
im sure that's obvious here though....
Rootdown4594 wrote:those cheap little plastic tools you get with associated kits. I use those more than anything just because you can toss them in your pocket.
...and they don't mar the white plastic nuts like dirty metal nutdrivers
Has thanked: 1748 times
Been thanked: 1149 times
Dirty dirty tools, marring poor gomachv's nuts..... they should be ashamed.
:shock:
RC10th
Has thanked: 54 times
Been thanked: 1574 times
Post by RC10th »
My basic tool pouch consists of;
Imperial Allen drivers
Metric Allen drivers
Imperial nut drivers
Metric nut drivers
Xacto knife
Body reamer
Sharpie pen
Scissors (normal)
Curved scissors
Needle nose pliars
Sprue cutters
Small jewelers flat blade
Pin vise
Turnbuckle wrench
GreenHell
Post by GreenHell »
Couldn't live without it. Compact and easy to take to the track.
"All I wanted was a Pepsi..."
My Gallery | My Feedback | Rapid_RC
Has thanked: 365 times
Been thanked: 478 times
GreenHell wrote:Couldn't live without it. Compact and easy to take to the track.
I was sure that I was going to see that 3D printer here!!
Has thanked: 3728 times
Been thanked: 1987 times
Is that Dremel brand or someone else? Got a link? Looks very cool.
GreenHell
Post by GreenHell »
Charlie don't surf wrote:I was sure that I was going to see that 3D printer here!!
It was under heavy consideration, just isn't very portable. :lol:
GreenHell
Post by GreenHell »
It is Dremel brand but unfortunately is discontinued. I've had mine for several years and it works great for small jobs.
limestang
Post by limestang »
I purchased this brand solder iron about 2 years ago, and have been very impressed wtih the performance. It heats up fast, and helps make great solder joints.
Hakko 456016 60W Solder Iron
$28 - Frys.com
limestang
Post by limestang »
I purchased a 7x12 mini-lathe about 8 years ago. I like this particular size because it's large enough to make hobby quality stuff, but not too big or heavy to store. If you've ever wanted to learn how to cut chips on a lathe, it's fairly safe to use and not super expensive. I self taugh myself, and over the years have been able to fabricate some pretty cool things. Some of them related to RC10's:)
- Limestang
8rad
Has thanked: 9 times
Been thanked: 38 times
Post by 8rad »
Shock shaft pliers. Nuff said!
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarSeznam [Bot] and 5 guests
