A little experiment with the B3
Quite literally a little experiment. I just picked up a Losi Mini 8ight, yanked the stock Excelorin 4500 kv system without even trying it and shoehorned a Velineon 28x45mm 380 can and Dynamite 70A 1/10 ESC in it. To put it mildly, that little 1/14 buggy is an animal now. lol.
Anyway, don't have another 1/16 or 1/18 that's in need of a power system at the moment, but I had yanked the Dynamite 5800KV can out of the B3 last week, as I was offering it as one of three motors to include in a trade. The fellow decided on the HW 9T motor, but I just didn't get around to reinstalling the 5800. Well, experience has shown me that 1/8 ESCs with 1/10 motors makes for a potent system, so..........why not try a little 24x35mm 280 can with a 60A 1/10 ESC in a light weight 1/10 buggy? Mounting is easy; just use the upper slot as intended, and put a decent washer on the lower screw so it bites the side of the pinion cut out on the motor plate.
Stuck with the 16T pinion that was on it in the mini 8ight, and it's surprisingly quick! I'll have to watch temps, but I really don't think it'll be an issue, as even with the 5000 mAh 2S pack, the B3 is just 12 ounces heavier than a stock mini 8ight.
I'll report back after I've had a chance to run it on the track.
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: A little experiment with the B3
I think JK Racing runs a 380 in one of his 1/10th racers and it works really well. I'm not sure what esc he might be running though.
- Has thanked: 7 times
- Been thanked: 42 times
Are any of the 380 size motors sensored? This would be an very tricky way to reduce rear weight bias in a rear motor buggy without going fully to a mid motor buggy.... hhhhmmmmmmm
- jamin
- Has thanked: 3 times
- Been thanked: 28 times
I think Novak do a brushless micro motor/speedo, quite expensive though - I was looking for one for my Mini-8.adam lancia wrote:Are any of the 380 size motors sensored? This would be an very tricky way to reduce rear weight bias in a rear motor buggy without going fully to a mid motor buggy.... hhhhmmmmmmm
Team Losi: XX-CR | XXT | XXT-CR Graphite+ | XX4 | Street Weapon IWC Edition
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
I still have that little 380 motor too
Its currently bolted up to an A&L Leathal Weapon. I used the speedo that came with it at first, then swapped over to a BHR (hobbywing clone). The little motor woke up with the bigger speedo. Love the little motor/big car idea, still great RPM, but torque is down compared to regular 540 motors, so a bit easier to drive on slippery tracks.
Post up pics, let's see your experiment.
That Velineon 28x45mm 380 can in the mini 8ight is a beast compared to the stock Excelorin 24x35mm. The mini 8ight is a tad on the heavy side as mini buggies go, definitely benefited from the extra torque. Sensorless, but plenty smooth with a decent 1/10 ESC, and you can soften the punch settings a lot without losing performance when this overpowered. Mine still turns into a jumping jack firework if I hammer it, but i can do nice, gentle slaloms at only 2-3 mph.I was looking for one for my Mini-8.
- 896 Views
Last post by mytimac
- 1628 Views
Last post by teman
- 3596 Views
Last post by JosephS
- 4218 Views
Last post by Y'ernat Al
- 29 Replies
- 5247 Views
Last post by isobarik
- 1107 Views
Last post by Lowgear
- 36 Replies
- 4955 Views
Last post by Frankentruck
