Futaba 27Mhz to 2.4Ghz
Miggers
Post by Miggers »
I have a tidy old Futaba Attack R 2channel 27Mhz(bought new in 1987)that I'm
wondering if it can be converted to 2.4Ghz?
I know there are DIY sets out there,but they all seen to be used on 35 & 72Mhz PCM sets.
Has anyone had a go at doing one of the old 27Mhz sets?
slow_jun
Re: Futaba 27Mhz to 2.4Ghz
Post by slow_jun »
did mine on a 27MHZ KO EXII set. Do some research first so that you will know what your getting into. Mine I used FRsky, should you go on that path, get the one with the telemetry as it has solved the servo Gitter problem. good luck.
http://www.rc10talk.com/viewtopic.php?f=78&t=20661
you just need to know the PPM signal and your off.
― Confucius
